02-19-2007, 09:09 AM | #1 |
67 chevy SWB Fleetside
A/C original or vintage air
Hoping to get some input here, trying to decide whether to attempt to source original parts or go for the easy way out. I would prefer an original system but am wondering, does anyone have a suggestion for where to get a complete set up, any condition, and if so, what do you think it would cost for the parts?
The vintage system looks to be about $1200 and would be new working condition. Could an old system be purchased for $500 and then I have to put in a lot of elbow grease? Thanks.
67 Chevy C10 Short Wide 350/350 ... Front Discs ... ECE Lowered 2.5/4 Vintage Air ... Oak Bed Floor ... Painless Wiring Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake Ididit Column ... VDO guages |
02-19-2007, 09:25 AM | #2 |
Active Member
Re: A/C original or vintage air
The new Gen IV system will cost you $900 minus the lines, compressor, condenser, ducting, and vents. That is what I plan to go with.
02-19-2007, 09:26 AM | #3 |
Check out Old Air....around $1k total. I'd go with one of those before the stock version hands down.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
02-19-2007, 10:30 AM | #4 |
I prefer the original system because of the look and the way the controls work. Costwise if you don't have anything to start with you will probably exceed $500 by a lot.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-19-2007, 01:45 PM | #5 |
67 is sold
My plan is to run the Vintage air system.
I really want a clean motor compartment |
02-19-2007, 02:04 PM | #6 |
I don't have Vintage Air yet. I have been doing some searching on it, and haven't found anybody that had anything bad to say about it. I am confident this will be the way I go.
Did your rig come with OEM A/C?
1972 Chevy LWB K10 Custom/Deluxe Earth first! We'll log the other planet's later. |
02-19-2007, 03:40 PM | #7 |
I have a cab that had the OEM A/C and am hoping to find a parts truck with most of the donor pieces, but didn't have any idea what to expect someone might want for them.
02-19-2007, 08:35 PM | #8 |
Because of the age of the trucks you will probably need to replace the hoses, condenser, condenser piping, receiver drier, blower motor, inside ducts, maybe the compressor, and also the diverter box since many don't work. Hopefully the evaporator, poa valve, and inlet valve are good.
If you want to redo your existing AC system, I would suggest getting a Service Manual for you truck as they have an excellent section on the system. Jim
02-20-2007, 12:57 AM | #9 |
Too Dumb To Know Better
Hey Idaho Outlaw, my brother lives in Nampa. He had a Vintage air in his 66. He took it out because he froze in the winter. It takes away your hot water heater. They work real good for those of us in the south.
02-20-2007, 10:42 PM | #10 |
WTB this ad
I have Vintage Air in both my trucks! My heat works fine but sometimes it wants to fog the windows. Either way dollar for dollar they are hard to beat! If you can follow instructions and have basic knowledge of hand tools you can install a Vintage Air kit.
