02-19-2007, 03:12 PM | #1 |
What rear diff do I have? '86 K20
I just bought a plow truck that has an open rear end, and would like to put a posi unit in instead. I have not checked to see what rear end I have, but was there one that was standard on 4x4 3/4 tons? The ratio is 4.10, and I believe it is an 8-lug truck. Are all 3/4 ton 8-lug? If a truck is equipped with a full floater rear end, A) would it show on the RPO tag in the glovebox? B) would a "dog dish" factory hubcap fit, or would it need to have the hole in the middle like a front differential hubcap has?
Just looking for some help on what I should keep my eyes peeled for. Thanks. -adam |
02-19-2007, 03:20 PM | #2 |
junk collector
Re: What rear diff do I have? '86 K20
is it a full floater? If so, 14 bolt, if not 14 bolt semi float
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
02-19-2007, 03:24 PM | #3 |
I'm not sure if its a full floater or not. Since I got the thing last week, the only thing I've had a chance to do is put a new starter in and blow a brake line; haven't even peeked at the diff. It does have the OEM steel wheels with hubcaps all the way around. Since the full-floater has that protruding part with the 8-bolts, similar to a front diff, would the stock hubcaps fit over that part? If I were to guess, I'd say its not a full-floater.
02-19-2007, 03:59 PM | #4 |
Right turn Clyde
I'm pretty sure it is a sf and not a ff but there is only one way to be sure. SF 9.5 ring and FF 10.5 ring
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
02-19-2007, 06:08 PM | #5 |
Wide n'Low
Take a look at the rear cover and go to one of the many sites that carry rear end goodies. Most of them have a diagram chart that shows the cover patern and identifies which rear you have. Might help you out.
This site may help http://www.ringpinion.com/DiffList.a...peID=5&Type=GM |
02-19-2007, 06:44 PM | #6 |
Wide n'Low
Here is a quick guide
