Old 02-19-2007, 04:02 PM   #1
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Question Please help stop the bouncing.
I have a 93 GCM sierra. Every time I press the brakes to stop my front end starts to bouncing up and down. I know it is not the back because I can fell it in the steering wheel. And it does not happen when I tried to stop the E-Brake. I have put new tires, front end alignment, brakes, shocks, and had the rotors turned. If any one has any ideas please let me know.
Thank You
Ralph Vega
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 02-19-2007, 04:34 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: Please help stop the bouncing.
Usually thats a front disk brake problem... Make sure your calipers and rotors are good
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-20-2007, 12:13 PM   #3
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Yha the calipers are fine I also had the rotos recut and new brakes installed.
Old 02-20-2007, 03:40 PM   #4
pharcyde05
pharcyde05's Avatar
toss the rotors dont waste the time of having them turned they worp the once you have them turned they are thinn and worp even faster
if you are set the the rotors arnt the problem then chack and see if you have front ABS and see if you have a problem with your module
pharcyde05 is offline   Reply With Quote
Old 02-20-2007, 11:10 PM   #5
19GMC63
19GMC63's Avatar
yep, measure the rotors with a dial indicator just to be sure
19GMC63 is offline   Reply With Quote
Old 02-20-2007, 11:44 PM   #6
st1x10
st1x10's Avatar
Have u tried unplugging the EBCM (electronic brake control module)?? Might try that, it is a problem with those that I have seen before.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 02-21-2007, 11:46 AM   #7
oj70chevy
250 V-6 Club
oj70chevy's Avatar
I am gessing I may have bad rotors. just wanted to ask, if the rotos are worped should my truck bounce or shake when driven? But disconnecting the EBCM would seem to be a free check before spending any money. Where is it and how do i unplug it? also is it safe to drive with it unpluged?
Ralph
Old 02-21-2007, 11:50 AM   #8
bobthecop
bobthecop's Avatar
Warped rotors cause a vibration or pulsation when brakes are applied, warping comes from rotors being hot and then quick cooled, or overheating. I have also seen rotors continue causing the pulsation when turned off the car, find a shop that can turn the rotors on the vehicle, or replace them, sometimes the rotors are not flush against the hub, and turning them off the car makes them true to themselves, not that they are bolted to.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
