Old 02-19-2007, 04:46 PM   #1
Zeke
Active Member
spread bed
How do you bring the top of the bed rails in so the tailgate will close? I thought about using a come-along connected to a tree and bend it in so it springs back to the correct spot.
Anyone have other ideas?
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 02-19-2007, 04:49 PM   #2
texascowboy593
texascowboy593's Avatar
Re: spread bed
I have the same problem as well. I thought of doing the same thing but its not high on the priority list. Intrested to see the responses... It does shut and lock on one side...If I slam it, both sides lock...
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 02-19-2007, 05:37 PM   #3
AH619
AH619's Avatar
Re: spread bed
My Bed Was Sprung Apart And To One Side. I Ground The Welds At The Bottom Corners Where The Bed Sides Meets The Floor.then Loosened The Bolts That Hold Both Peices Togather. Then Use One Ratchet Strap From Stake Pocket To Stake Pocket,pull The Bedsides Togather To The Correct Distance.then Use A Large Square To Check That They Are Not Leaning One Way Or The Other.when You Have It Right Both Sides Will Be Square.now For The Trick.after You Tighten Everything And Reweld At The Bottom The Sides Are Going To Spring Out About 1/4 Inch. So I Pulled Mine Togather An Extra 1/4.when I Loosened My Ratchet Strap Everything Was Square. If Your Sides Are Leaning Use A 2nd Ratchet Strap From Top Of Leaning Out Side To Bottom Of Leaning In Side And Pull Till Its Square. Sorry This Is So Long But I Hope It Helps
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 02-19-2007, 08:31 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: spread bed
I did the come-a-long trick, and it took a few tries, but it solved the problem. It was never perfect, but it was a junk bed to begin with.
Old 02-20-2007, 02:38 AM   #5
Aarons72s
Re: spread bed
I have used the ratchet strap method, worked good for me. Just be sure to use a large one and not the small one's. It takes a few pulls but works pretty well.
Aarons72s is offline   Reply With Quote
Old 02-20-2007, 11:57 AM   #6
Re: spread bed
The only way to absolutely control the amount you move a given side would be to not pull one side against the other.Not saying it can`t work.But,you need to immitate what "rack" in a body shop does.A come-along to a tree or other stationary object is good.But,could pull the whole truck to the tree.So,you would anchor the truck in the opposite direction at a point on the frame or axle to keep it rigid and all force focused on the bedside.
Old 03-05-2007, 05:54 PM   #7
Zeke
Active Member
Re: spread bed
come-a-long worked great. it was only spread out 1/2" each side. thanks
1969 C10 350 3spd
