02-19-2007, 04:47 PM | #1 |
Decision time
I guess it's time to make a couple of decisions with my '58 step side. I already pretty much know what engine, tranny, rear end, tires, wheels, color the and interior is going to be.
I just haven't decided on the front clip. The truck came with a complete Camero clip if i want it. I can't decide between the Camero clip or a front suspension from Fatman's, Heidts, TCI, etc. The Camero clip will have to be rebuilt. That's no big deal. The wife works for a major parts chain so price isn't that much of a factor. Lots of work to install. An aftermarket Mustang type set up will be all new and much easier to install. That's my problem. I trust my welding enough to do rear ends, motor mounts, etc., but not really enough to do a Camero install so that one would have to be farmed out. I could do the aftermarket front end if i took my time, measured often, weld a little, measure... Then comes the master cylinder. Use the stock pedal set up or go with a firewall mounted set up? Keep in mind, this will be a daily driver, but i'll enter a local show now and then, so i'm looking for clean, simple and reliable. Any thoughts? |
02-19-2007, 06:56 PM | #2 |
Hollister Road Co.
Re: Decision time
Decide on the suspension then find the welder. You could most likely get a pro welder for a day at a few hundered bucks. Find someone who does pipeline or heavy equipment. Or tack it up good and drag it to a weld shop.
As for master cyl, thats a personal preference. I have a hydraboost on my firewall. It could just as well go under the cab. I go with the idea that if your doing what everyone else is doing hide it. If your doing trick stuff put it in plain site. I think on mine if it was just a regular master I would have gone under the cab. I haven't seen to many hydraboosts on 55-59 truck so I put it on the firewal. |
02-21-2007, 11:29 AM | #3 |
Re: Decision time
you could do the camaro clip and probably come out ahead. go to jalopyjournal.com then click on the HAMB at the top of the page. it is a forum for old car guys. scroll down and there is a thread on camaro clip in a 58 that is awesome. incredible pictures and instructions even i can follow - and am, starting this week.
02-21-2007, 11:34 AM | #4 |
Re: Decision time
oh yeah, duh me, see 56chevy1300's project on this board. another awesome buildup record that addresses some of your questions and how to do a clip.
02-21-2007, 11:57 AM | #5 |
Re: Decision time
I'm not sure about your "Task Force" style truck, but on the "Advance Design" trucks, like my '54, the Camaro front end Changes the front end width and forces you to use a certain off set front wheel in order to tuck the wheels back inside the fender. This is on reason I chose the Mudstane II front. Not to mention it's got all new parts to start with aand if you want to bag it, you can.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
02-21-2007, 01:01 PM | #6 |
Re: Decision time
You may also want to look at Industrialchassisinc.com Steve has some Very good ideas and proven results.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-21-2007, 01:08 PM | #7 |
Re: Decision time
Mine is on a Camaro ,& I love It !!
http://i142.photobucket.com/albums/r...MyExtremeD.jpg ~ '55 Chevy Pro-Street P.U. Powered by 396c.i. ~ ~ '01 ChevyS10 Extreme LS Ext. cab ~ '92 Camaro RS 25TH.Limited Edition Aniv.Convert. ~ '98 Dodge Ram Van 5.7 Litre ~ '98 E-Z-GO Golf Car ..Tony Stewart Edition !! '69 Camaro SS..SOLD .. Still crying !! Last edited by Sweet&LowPro55; 02-21-2007 at 10:57 PM. |
02-21-2007, 01:30 PM | #8 |
Re: Decision time
Camaro vs. Mustang II is really a personal preference. I have a Camaro clip on mine that fits nicely. The pros and cons would be, Mustang II has rack and pinion steering but is much more expensive to do. The Camaro is the less expensive way and you can get parts at any parts store cheap. If I had to pick between the two, I really could go either way. As for the brake set up, I went with the frame mount. I wanted to keep my firewall smooth. I would defiantly replace the stock master cylinder either way with a dual chamber style for safety reasons. By the way, I see you’re from Fresno, which makes you my neighbor since I'm in Clovis.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 02-21-2007 at 01:35 PM. |
02-21-2007, 11:05 PM | #9 |
Re: Decision time
Cal 58 GMC...you have one awesome truck .
great job you've done !!!!
http://i142.photobucket.com/albums/r...MyExtremeD.jpg ~ '55 Chevy Pro-Street P.U. Powered by 396c.i. ~ ~ '01 ChevyS10 Extreme LS Ext. cab ~ '92 Camaro RS 25TH.Limited Edition Aniv.Convert. ~ '98 Dodge Ram Van 5.7 Litre ~ '98 E-Z-GO Golf Car ..Tony Stewart Edition !! '69 Camaro SS..SOLD .. Still crying !! |
02-22-2007, 08:11 PM | #10 |
Re: Decision time
Thanks Sweet&LowPro55!! Yours is rather awesome too!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
02-22-2007, 11:21 PM | #11 |
Re: Decision time
[QUOTE=CAL 58 GMC;2042117 By the way, I see you’re from Fresno, which makes you my neighbor since I'm in Clovis.[/QUOTE]
Hi neighbor. My son and one of my sisters live in Clovis. I read your build thread....that's one fine truck. |
