02-19-2007, 07:16 PM | #1 | |||
Union Electrician
Cleaning up lots of parts FS
I am cleaning out and getting rid of the stuff I don't need and aren't going to use. I will post a pic or two for now and it you want to see something specifically just ask and I will get close up of what you want to see.REPLY ONLY herein the thread NO PM's to keep it all in the open and fair. I prefer paypal but will accept a US postal MO. Thanks...Randy
List of parts 1) battery tray, have some minor pitting and one little spot of rust on the front left corner, not seen when installed.. $25 shipped 2)7 blade clutch fan 17.5" diameter condition unknown $35 shipped SOLD 3)5 blade clutchfan has one bent blade,but should be able to fix $15 shipped 4) brake booster and m/c combo with mounting brackets and one other braket, no prop vavle, conditoin unknown $25 plus ship 5)fram mount exhaust hanger? $10 shipped 6)2- wiper motors condition unknown $10 shipped/each 7)2 voltage reg both worked well when pulled $7 shipped/each 8)speaker braket $7 shipped 9)starter for sbc condtion unknown, was on a daily driver that caught fire but didn't get the starter hot, should be ok, but assume it's a core, $10 plus ship 10) oil pump and rod, worked good when removed $15 shipped 11)black sunvisors pair driver shape with rods $25 shipped SOLD 12) NIP non tilt turn signal lever and knob $10 shipped 13)2' 5/16 fuel line with 4 clamps $8 shipped 14)sbc v-8 engine stands good condition $25 shipped 15) 2 sets of lower shock mounts for coil spring rears, one has been cleaned and painted with eastwoods two part converter, rust encapsulator, and high gloss chassis black $25 shipped, the other pair is original untouched $15 shipped sold 16)2 power sterring pumps, both with one bracket, one missing cap, condition unknown $25 shipped/each 17)bracket in middle unknown? $5 shipped 18)2 partial door latches, with inned and outer plater and bolts, no shims $10 shipped 19)5 glove box doors in fair condition,2 67-8 style, $10 shipped/each or deal formore than one. 20)2 pieces of original GM rocker panels, they have been cut and drilled out to get to the inners.(see pics, they are not complete) They are nice and solid and could be used to patch up some spots in your rockers, $30 shipped for the pair. 21)1 set of 3:73 gears stamped 11:41 with open carrier , ring and pinion, and all associated parts out of a 6 lug 12 bolt rear,in good condition. The gears are in good condition show little wear. All bearings, spiders gears, pin,shims, bolts, ect... I just took out everything out of the rear end and put it in a bucket to keep it all together. Theses came out of Frank and would be great for a driver $40 plus ship 22) set #2 3:73 gears stamped 11:41,open carrier same thing as above, I took everything out of the rear end and put it in a bucket to keep it all together. This set of gears has some small spots of light surface rust, but look descent overall, this set also came from a 6 lug 12 bolt rear.$20 plus ship 23)67-8 non tilt auto column with shaft, has good fiber optic, but needs new idicator, wiring is good, levers and wheel are junk, $20 plus ship, wheel is free with column if wnated $12 extra to ship. 24) non tilt auto column, in good condition, has good fiber optic, needs indicator, levers are ok for driver, wiring is good, wheel and the shaft are not included $30 plus shipping. 25) steering wheel w cheverolet wrote on it, 4 spoke off 88-93 something, nice and tight not all chewed up and loose, $50 plus ship FIRM 26) heater control with broken fan control lever, rough looking but sound could be restored easily with a kit, cables are junk and not included $10 shipped. All prices OBO...Thanks
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
02-19-2007, 07:19 PM | #2 | |||
Union Electrician
Re: Cleaning up lots of parts FS
more pics
02-19-2007, 07:21 PM | #3 | |||
Union Electrician
a few more...
02-19-2007, 07:28 PM | #4 | |||
Union Electrician
couple more
02-19-2007, 08:13 PM | #5 |
Not a bad nut after all..
Is the black "Chevrolet" horn button on the late model steering wheel for sale?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
02-19-2007, 08:26 PM | #6 | |||
Union Electrician
no the wheel is for sale and the button goes with it
02-19-2007, 10:07 PM | #7 |
Are the visors in good shape on both sides, no tears and etc? If they are in good shape I will take them. Thanx Dana
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
02-19-2007, 10:15 PM | #8 |
i will take the 7 blade fan and do you take pay pal ? thanks mark
p.m. me the info please. Last edited by rage'nrat638; 02-19-2007 at 10:35 PM. |
02-19-2007, 10:39 PM | #9 | ||||
Union Electrician
I will PM you payment info...Randy
02-19-2007, 10:40 PM | #10 | |||
Union Electrician
PM ON THE way, yes on paypal...Randy
02-19-2007, 10:51 PM | #11 |
cash sent thanks buddy
02-20-2007, 12:29 AM | #12 |
I'll take the pair of untouched lower shock mounts for coil spring rears for $15 shipped. Please PM your info. Thanks
02-20-2007, 12:35 AM | #13 |
cash just sent for visors...thanks
Dana
02-20-2007, 01:11 AM | #14 | |||
Union Electrician
PM sent
02-20-2007, 10:08 AM | #15 |
Can you get me a total price on #22 for just the ring and pinion gear to 08753?
Thanks.
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
02-20-2007, 04:30 PM | #16 |
What yr model is the powerbrake booster setup and does the rod that runs to the brake pedal come with it, didnt see it in pic.
thanks Big O.
Things happen for a reason! |
02-20-2007, 07:28 PM | #17 | |||
Union Electrician
I will check on it and LYK
02-20-2007, 07:30 PM | #18 | ||||
Union Electrician
It came off a 72 and no the pedal rod is not with, but I believe I may have it. If I have it I will throw it in, I will check and LYK.
02-22-2007, 12:57 AM | #19 | |||
Union Electrician
bab4x4,ragenrat,67babyblue
Your stuff is going out in the morning. Thanks!! ScottH, how does $40 shipped sound?
02-22-2007, 07:06 AM | #20 |
I'm interested in the speaker bracket, where does it mount, in the top of the dash or under the heater control panel? J
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-22-2007, 08:08 AM | #21 | |||
Union Electrician
This one is for the top of the dash between the defrost vents.
02-22-2007, 06:56 PM | #22 |
Thanks Byrd for gettin back to me, but I don't have the time to cut up my dash right now.
02-22-2007, 11:33 PM | #23 |
Do you still have the brake booster? If so, do you know if it will fit a 68 C10, I measured the firewall mount and the bolts from top to bottom are 2 3/4 and from side to side 3 1/2. And what would it cost for shipping to Okla. 74447?
Thanks, Sam |
02-23-2007, 05:45 PM | #24 | |||
Union Electrician
Haven't been able to find it..
02-23-2007, 05:46 PM | #25 | ||||
Union Electrician
Sure do, and yes it will bolt right up, $50 shipped.
