Old 02-19-2007, 09:38 PM   #1
GREASEMONKEY72
GREASEMONKEY72's Avatar
speedo problem
ok i posted a little while back about my speedo stoping at 85mph and asking why it wouldnt go over that, well i compared my speedo to my brothers truck a ford f-250 supercrew and found out that mine is about 5mph off from his so my question is, is the gears in the tranny the only thing controling the speed or is there gears in the speedo itself that could affect it, and could the gears in the tranny be the reason it doesnt count over 85mph??? o and just for refernce it went up to 85 and stayed then jumped to 90 and bounced around between them then went back to 85 and stayed, ok enough rambling
THANKS FOR ANY AND ALL HELP AND COMMENTS
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-19-2007, 11:57 PM   #2
GREASEMONKEY72
Re: speedo problem
ttt
-steven
Alte Seele S.S.
Old 02-20-2007, 12:04 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: speedo problem
If the speedo jumps it's either the speedo or the cable. With a worn cable you usually get a lot of fluttering.
I would start by inspecting the cable. Disconnect at the speedo, and it pulls out of the housing. If it's frayed or worn, replace it. If the lube is dry, you can get some cable lube and work it into the cable. Graphite base grease, so it is a mess.
If that doesn't fix it, it will be the speedo. They can be rebuilt and calibrated. Sounds like you have worn or dry gears in the speedo, but the cable is an easier and cheaper fix.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-20-2007, 12:34 AM   #4
GREASEMONKEY72
Re: speedo problem
ok thanks Fred T, ill do that and see what happens and go from there
-steven
Alte Seele S.S.
