Old 02-20-2007, 02:05 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
67 LWB going to the scrap yard in 30 days
So if you see something you need, post it here and i'll cut it out. the truck is being stored about 2 hours from me, and i don't plan to get back up there until Mar 10 at the earliest. my plan is to see if anyone wants parts now, make a list, then pull them all at once and ship them the following monday.
Most of the bed is in pretty good shape. There are a few dents and some rust, but i'm guessing someone will see something they need.
the dash is uncut, but i'd be willing to cut it.
It's a 6 lug setup with drums all the way around. Trailing arms and cross member are gone, and the P side fender is shot, but the trim is good. the axle is an open 12 bolt, had some metal in the oil. bed floor is shot. not even worth cut pieces from. The grill guard is posted in another thread as are some of the other parts.
Oh, and the hood is still there (not pictured) with all of the letters. no dents that i saw, and no holes. very slight surface rust in a couple spots. The O has one peg that is broke, but there is still enough there to keep it in place... just glue it or something. $40 for the hood, no shipping
The D side fender is ok. has one small rust hole near the door, and one dent in the lower cup. that dent would be covered by a factor bumper though. also, the D side inner fender is still in good shape. $40 for both the outer and inner D side fender. no shipping
Please no PM's!! Post what you want here.
At this point, if the piece is less than 2' x 2', i'm thinkin around $10 per part. Tell me what you want, and your zip, and i'll get you a quote w/ shipping ASAP.
I do take PayPal and Money Orders.
IvelDesigns is offline   Reply With Quote
Old 02-20-2007, 02:07 AM   #2
IvelDesigns
Re: 67 LWB going to the scrap yard in 30 days
more pics
Old 02-20-2007, 02:19 AM   #3
CrashEd
72 chevy
CrashEd's Avatar
Is the tailgate any good.
CrashEd is offline   Reply With Quote
Old 02-20-2007, 02:31 AM   #4
IvelDesigns
nope, it's junk. handle is bent, gate is bent, and has holes in the bottom. at most, the lettering may be good, but probably not worth cutting out and shipping.
Old 02-20-2007, 02:36 AM   #5
CrashEd
72 chevy
CrashEd's Avatar
Ok thanks
Old 02-20-2007, 03:12 AM   #6
brak
brak's Avatar
Where in Iowa is the truck...
I'd be interested in the steering column and possibly the rear end.
picking up should be no problem
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-20-2007, 06:56 AM   #7
kohler
kohler's Avatar
how about the front light harness,shipped to 12401
thanks chris
kohler is offline   Reply With Quote
Old 02-20-2007, 10:19 AM   #8
IvelDesigns
thanks chris
junk. most of the wiring was rigged together, so i got a bit happy with the wire cutters when pulling things apart.
Old 02-20-2007, 10:20 AM   #9
IvelDesigns
The truck is in Dike Iowa, about 10 miles west of cedar falls/waterloo. I'll PM you with contact info.
Old 02-20-2007, 07:34 PM   #10
grant's72
grant's72's Avatar
if the back of the box is good I mite take this part if you have a pic Of the back I would like to see it too
grant's72 is offline   Reply With Quote
Old 02-20-2007, 08:16 PM   #11
Bob Moore
3 very small items for a buddy.
1. The neutral safty switch if this truck was a powerglide
2. Again if powerglide, the PRNDL lens from the column.
3. The rubber stop(block) the gas pedal hits on the floor. Accessible from the engine side of the firewall.
One more as I think about it - again if powerglide - the kick-down linkage rod from the carb all the way down to the transmission. Maybe 3 pieces total? A rod from carb, a lever type setup on the bellhousing(?), and another rod to the transmission.
Shipped to zip 98407 Tacoma, WA
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-20-2007, 09:25 PM   #12
67arch
WTB:Patience and Talent
67arch's Avatar
I'm interested in rearview mirror if not to fogged.
auto column, need auto trans crossmember.
also passenger roof section from back seam to front driprail. From pass. driprail 12" in. Let me know if possible. Thanks
69 shortwide
67arch is offline   Reply With Quote
Old 02-20-2007, 09:47 PM   #13
kohler
kohler's Avatar
thanks anyway
Old 02-20-2007, 10:31 PM   #14
IvelDesigns
i didn't look to close, but the P side corner might be good. it does have a lens in it, so the chances are pretty good that it's in good shape. when i go up, i'll cut it out if it is in good shape and PM you a pic.
$10 + S & H and i'll leave the light and lens in it.
** edit **
just realized you are in iowa. if you want, you can come get it if you are close to waterloo to save the shipping. might be worth the trip if you're looking for other parts. PM me with your location
Old 02-20-2007, 10:35 PM   #15
IvelDesigns
it was a powerglide, but has a 350 in it now. I'm not sure if the lens is still the PRNDL one or not, but if it is, i'll pull it. it's probably not in great shape though. the linkage is all 350 linkage, so no luck there.
when i go up there next i'll pull the parts and PM you the pics.
Old 02-20-2007, 10:46 PM   #16
IvelDesigns
brak is first in line on the column.
i'm waiting to see if i can sell the rear wall before cutting the roof. also, i think there is rust along the drip rail, but i will look the next time i'm up there.
when i pull the engine/tranny (that same weekend) i'll look to see if the tranny member is good or not. $10 + S & H for it
the mirror is good and clear and not cracked if i'm not mistaken. $5 + S & H for the mirror
Old 02-21-2007, 12:31 AM   #17
Bob Moore
Sounds good. Thanks - Bob
vac, 454, T400
more to follow
Old 02-21-2007, 05:40 PM   #18
70STOVEBOLT
70STOVEBOLT's Avatar
How about the shift indicator pointer? I dont' need the lens or the chrome part, just the pointer itself. Nobody makes 'em aftermarket that I can find, only the 70-72 style. Thanks, stovebolt
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-21-2007, 11:19 PM   #19
67arch
67arch's Avatar
Sounds good, I want the mirror and hopefully tranny member is good also. Let me know on roof.
69 shortwide
Old 02-21-2007, 11:23 PM   #20
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Levi, is the pointer for the shift indicator any good? I accidentally broke mine.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-21-2007, 11:41 PM   #21
BCOWANWHEELS
i want the throttle pedel and the steel rod linkage. got it?
bob
kingsport, tn. 37664
BCOWANWHEELS is offline   Reply With Quote
Old 02-22-2007, 12:22 AM   #22
IvelDesigns
1badSS/70STOVEBOLT
brak has claimed the column pending payment. if he doesn't take it, i'll check the pointer to see if it's good or not. if my memory is right, it's not.
Old 02-22-2007, 12:23 AM   #23
IvelDesigns
$5 for the pedal. it's posted in another thread. not sure on the linkage. when i go up there next, i'll check for it and PM you.
bob
Old 02-22-2007, 06:58 AM   #24
BarryB
BarryB's Avatar
I am interested in the door and fender trim. how much and shipping to 37617.
BarryB is offline   Reply With Quote
Old 02-22-2007, 07:41 AM   #25
Snohog
Junior Member
Snohog's Avatar
Is the core support any good?
68 SWB all over the garage
86 LWB silverado
2006 silverado SS
Snohog is offline   Reply With Quote
