Old 02-20-2007, 12:14 PM   #1
Eliasj123
How Do I Get a Smoother Ride?? 64 Fleet C20
Hey,
I've been driving my 64 more and more and was wondering what should I do to get a smoother ride..
I already know that I should replace the shocks... But what about the springs?? Or anything else??
Do tires make a difference?? Also, was wondering what the stock tire size is for 64 C20...
Thanks,
Elias
Eliasj123 is offline   Reply With Quote
Old 02-20-2007, 03:48 PM   #2
SIR
SIR
SIR's Avatar
Re: How Do I Get a Smoother Ride?? 64 Fleet C20
...300 lbs of sand should do it...good for traction too..
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 02-20-2007, 08:14 PM   #3
Eliasj123
Should I lay the sand out evenly?? Or all at the back of the bed??
LOL.. J/K.. I know you were joking..
Elias
Old 02-20-2007, 09:15 PM   #4
zenish
i used to have a 69 c20 camper special.i unhooked the shocks and left them unhooked.the springs were so stiff it still wasn't boincey.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 02-20-2007, 09:24 PM   #5
slepysal
slepysal's Avatar
What kind of tires are you running? Do you plan on hauling , or towing?
slepysal is offline   Reply With Quote
Old 02-20-2007, 10:06 PM   #6
Eliasj123
I have old tires with a ton of cracks in them.. The rear are 265's "Touring" and the fronts are 245's Michelin tires on stock rims..
I'm going to get new tires all around... Stock size.. whatever size that is...
No towing or hauling.. Just cruising around town with the occasional trip to the hardware store..
Thanks,
Elias
Old 02-20-2007, 10:33 PM   #7
slepysal
slepysal's Avatar
Shoot I thought you may have had some L/T ( light truck ) tires on it.
You could probably go with a p2357515 tire if you have 15" rims it isnt the best for heavy loads but rides ok
If they are 16" try getting a "SUV" type tire. With so many people buying 4x4 that will never see the off road, tire companies are making tires for this type of vehical. Piriellie scoripons, Bridgestone Duelers st , Dunlop tg 35's etc
They have a softer ridie then Truck specific tires. Hopes this helps.
Old 02-21-2007, 11:07 AM   #8
PrerunnerRob
PrerunnerRob's Avatar
Is your truck coil or leaf spring in the rear? If it is coils, go and grab some half tom coil springs.
PrerunnerRob is offline   Reply With Quote
Old 02-21-2007, 01:12 PM   #9
Eliasj123
I coils in the rear... Hmmm... Good suggestion... That should help, along with the tires...
There's also what looks like a half leaf spring in the rear. One catalog says it's a auxiliary leaf spring.. Do you guys I can remove it and be ok??
Thanks,
Elias
Old 02-21-2007, 11:03 PM   #10
SIR
SIR
SIR's Avatar
Thanks,
Elias
you most likely don't need it..just take it off and put it away....could be used for "barter" one day...
Old 02-24-2007, 09:44 AM   #11
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Definately get some softer side wall tires, if know 'heavy' hauling/towing will be done.
Just like 'Pre-bob' said, swap out the coils from some 1/2 tons..I would probably do the fronts as well.
Overloads have to go too.
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-24-2007, 12:06 PM   #12
Kager67
what knocking sound?
Kager67's Avatar
Funny you should ask. I just did this to my 64 c20 last fall. It rode like a lumber wagon before. Just order new half ton springs, they bolt right in. The ol girl rides like a caddy now. It makes it a lot nicer for cruisin.
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Old 02-24-2007, 10:44 PM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
well the extra leaf spring is cool wish i could of had some about 7 years ago i've owned the truck i have for 17 years hualing scrap Iron and i've ran more tired then most of the guys in here have had cars or trucks But one thing they for got to tell you about the 3/4 ton trucks most had 411 rear gears in the back so at 45 mph your eng is doing 3500 rpms or more there not fun to drive and there is no way you ever make it onto a freeway with 15 inch tires cus at 55 your at 6500 rpms and then its rod nocking time to get the mileage and the comfurt out of your truck and run the 411 or 410 gear run a radial i run a 10 ply XCP Michelin 235 85 16 now these tire are caddy tires for these trucks there smooth none aggresive tread there high way tread but there 235.00 a tire but Michelin makes one of the softest rubber compounds for side walls on the market but they do make a none 10 ply radial tire that would do you good remmber buy road hazzerd it will pay for it self
now my only stant on this subject why not go out and buy a 1973--87 1/2 and just have your old pads welded on to the rear end and convert to 1/2 ton 5 lug then you get the better gears like 305 325 355 373 wonderful crusine gears and you get disc brakes all at one time it all bolts up the same in the front end but you have to oval out 2 bolt holes to get all 14 bolts to go into frame for front end but 12 bolts should hold that front end in
stsalvage is offline   Reply With Quote
Old 02-25-2007, 01:24 AM   #14
Eliasj123
Instead of working on the house today like I should have, I removed the aux leaf spring and the massive rear bumper that weighed 100lbs.. Boy, does it ride smoother....
It's now a smooth enough ride where I can move on to the next thing... like body work.. Down the road, I'll get 1/2ton springs... and shocks.... oh yeah, and tires.... I think I need tires first....
So, are 235's going to be ok with the 3/4 ton gears?? Were 235's stock for 3/4 ton?? If not, what was??
Thanks Again,
Elias
