Old 02-20-2007, 02:29 PM   #1
billy37380
Junior Member
Wiper Cowl Question
On The Wiper Cowl What Are The Vents For Can They Be Taken Out Or Do You Need Them I Only Have A Heated Cab No A/c
billy37380 is offline   Reply With Quote
Old 02-20-2007, 02:33 PM   #2
Inthuwind
Straight jacket required
Inthuwind's Avatar
Re: Wiper Cowl Question
I believe you can take them out, or put a screen under them to keep the trash out. It's a rain gutter!!
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-20-2007, 02:33 PM   #3
Inthuwind
Inthuwind's Avatar
It's for vented air down to your kick panel vents BTW.
Old 02-20-2007, 02:53 PM   #4
timcos
Chief Honcho In Charge
timcos's Avatar
If you close them over (which in itself is not a bad idea) you will not have forced fresh air when going down the street. Or your a/c operation will not be able to bring in fresh air for its operation. I am sure there are other methods for hosing in some air. I have not seen them.
If I need fresh air...I surely crack open a vent window.
I have heard that if you are going to weld them over...that you do it in place as it flexes a lot.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 02-20-2007, 05:26 PM   #5
zden
does anyone reproduce a solid one?
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 02-20-2007, 05:36 PM   #6
As2rd
As2rd's Avatar
Sorry to bump in with a different subject, but how do you get the wiper arms outta the way to get access to the cowl vents. I have ripped nasty metal screen poorly placed in mine. I want to replace it with a much nicer chrome mesh piece.---Andy
As2rd is offline   Reply With Quote
Old 02-20-2007, 06:03 PM   #7
whatnow123
whatnow123's Avatar
this is just my opinion, but I believe that the vents in the cowl area happen to be the main source for all our rust issues, at least 90% anyway. I would like to close mine up as well. I have already closed up the vent doors and have vintage air, but I just don't have the skills to cut it out and close it up, not to mention it is pretty flimsy piece already.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 02-20-2007, 06:06 PM   #8
whatnow123
whatnow123's Avatar
There is a very small tab where the wiper blade attaches to the shaft near the cowl. Get a little screwdriver move that tab away from the shaft and the wiper arms will pop right off.
Build thread:
Old 02-20-2007, 07:05 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The vendors will have screens for the cowl vents.They keep about 75% of the trash out and what does get thru is small enough to fall or be washed out the drains.If you install the screens and keep the drains cleared the problem will be gone.
If you use the screens the easy way to install them is to remove the cowl then tie wrap or twist tie the screens to the cowl cover.When you reinstall the cowl and have everything lined up and the screws started,you can cut the ties.
BTW I think the screens run about $30.00-40.00 and come in powdercoated black or stainless(May be a little higher).
Just another option.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-20-2007, 08:27 PM   #10
Hooker
aka TEX-TOY
Hooker's Avatar
Could you use that area for a "cowl induction" system for the air intake.... Maybe cut a hole in the firewall and hoook it to the carb? Just a thought i had while reading this! Let me know
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!!
BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!!
Hooker is offline   Reply With Quote
Old 02-20-2007, 09:58 PM   #11
Inthuwind
Inthuwind's Avatar
Hey Panel, which vendor carries these?
