how do i remove my wing windows??
ive got all the screws out but the wing window frame wont clear the door frame and come out ??
who has done this before ?? |
Active Member
Re: how do i remove my wing windows??
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Having just done mine, these were a great help. The second post here is an index for FAQ for door issues. It is a big help to remove the 2 bottom screws on the back track, and loosen the top one. That will allow you to slide the regular window back a couple of inches. That is just about enough room to get the vent window out. I was just putting mine back in, and that came back to me. Last edited by Yeller68; 02-20-2007 at 07:50 PM. Reason: remembered something else. |
mine was easy all I did was open it. lol
J/k Did you take the regular window out? I know when i did my 79 yrs ago I hadto dismantle everything in the door to get it out
72 ![]() |
if you dont take the regular window out be carful not to scratch your regualr window because its easy to pinch it between the vent window track and the door and chip and scratch it badly
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
