what should i do??
i cant decide if i want to do the one pice window kit or leave the wing windows in my 68 swb. i will be installing a power window kit after i paint.
what do you think one pice?, or wing window? is it possible to instal the one pice windows later (put the wing windows in for now after i paint and then upgrade to one pice) or should i just go with the one pice right off the bat ??? |
Re: what should i do??
Are you going for a stock or custom look? You can put the wings in for now and always convert later but you have to deal with 2 of the 3 screws that held the wing window in if you remove them later. So If you dont mind a couple of holes or having to fill and touch up the paint later then you can do it latter. That is my thoughts.
I would recommend the new one piece windows without the small triangle. I think it looks cleaner than the small triangle. I think Captain Kaos(?) had a thread on this.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
In Memoriam...
Personally, I dig the wing vents. Looks classic...
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
