700r guys
can i get a pic of what kind of bracket you guys are running with the tv cable and intake. Have a regular gm alminum intake 1406 edlb carb and bracket fram summit. and spacer from autozone bracket only long enough to hook in hole by throttle linkage
tci-376700 bracket thanks chico
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold ![]() Last edited by paaw; 02-22-2007 at 06:37 PM. Reason: adding picture |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: 700r guys
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Re: 700r guys
I second BTO, great product.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Parts and more parts
Re: 700r guys
I took the one that I got from Preimere Performance (Now JET) and remodeled it to a better design and then made my own.
Re: 700r guys
I use the BTO one.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: Nov 2004
Re: 700r guys
BTO is the ONLY way to go, in my opinion.
Not a good pic, but only one I got. I can post a better one tomorrow of the completed set-up if needed. The cable plugs into the BTO bracket and you add a cam device to your carb (everything is included in the kit). Seriously, it took about 1/2 hour to install. I had the pan off the tranny and adjusted it by checking the plunger depth and then I fine tuned it using a trans pressure gage.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-21-2007 at 09:19 AM. |
Re: 700r guys
i got the bracket that bolts to the intake where the square part of the tv cable clicks in and it bolts right up to the manifold and than i got a B&M cable and B&M adapter that bolted to my edelbrock carb. i havent had a problem since.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
To The Levy
Re: 700r guys
I would agree with the bto guys, thats where mine come from, along with the braided tv cable. There sight also has plenty of insight of setting pressures , which is so critical on these trannys. good luck
Re: 700r guys
Here's what the BTO set-up looks like:
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: 700r guys
does anyone have a picture that is using the bracket
1997 pontiac grand prix gt (daily driver) for now; 2004 dodge ram quad cab (wife's truck) 4.7; 2000 pontiac booneville (wife daily driver) 1972 chevy cheyenne 350 bored 40 over 700r trans 373 gears ( posi) soon to be daily driver; 2002 gsxr750 sold ![]() |
Re: 700r guys
The problem isnt so much the bracket, when using the TV cable for the 700R4 or 200R4 most any bracket will work, the real problem with most carbs is the linkage angle on the carb for the TV cable isnt correct, it has to be right or you will be fighting to get the trans to shift properly. Hollleys, Edle, Demons and a few others need the adapter for the carb and BTO's kit gives you the adapter you need and a proper fitting throttle/tv cable adapter.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
Re: 700r guys
i had the BTO and think it is a waste of money. i never could get it adjusted properly. i ended up getting a factory bracket and have not had any trouble since. the part number for the factory bracket is #14077903. it cost me $9 which is a hell of alot better than $125 for the bto kit.
1966 Chevrolet Suburban 1955 Chevrolet Bel Air |
#13 | |
Re: 700r guys
#14 |
Re: 700r guys
what all will i need to get with the bto kit, this is all i need to get done before i can start driving tired of it sitting in the garage
#15 |
Re: 700r guys
did you guys have to drop pan and but spring in, don't know much about that, is the TVEZ1406 the one I need
