Old 02-20-2007, 10:54 PM   #1
skokie
skokie's Avatar
New 6 3/4 Balancer
I originally bought a 8 inch but in the mock up the balancer looked like it would hit the power steering brackets once installed onto the crank. I went and got a 6 3/4 one like the one before and then I noticed something.
On the old one the keyway slot is lined up at about 2 degrees. On the new one its lined up with 10 degrees. Do I need to worry about this? Why the difference?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-20-2007, 11:19 PM   #2
kaycee
kaycee's Avatar
Re: New 6 3/4 Balancer
The smaller 1 were used on 327 and 283 ,the bigger 1's were for the 350' you could get a different timming pointer and go from there.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-20-2007, 11:45 PM   #3
skokie
skokie's Avatar
The engine is a 350 and it came with a 6 3/4. Just strange to me that the key way slot is not in the same place.
68 build thread
Old 02-21-2007, 12:18 AM   #4
BCOWANWHEELS
most likely the old balancer has slipped inside the rubber elastomer. is the rubber cracked up bad between the 2 halfs.
BCOWANWHEELS is offline   Reply With Quote
Old 02-21-2007, 12:19 AM   #5
skokie
skokie's Avatar
Yep think you are right. I mocked up the new one and it looks good.
68 build thread
