Old 02-20-2007, 11:32 PM   #1
smh292
Airbags up front with drum brakes?
I'm just curious if it is possible to install one of the front bag kits up front and keep the drum brake setup on a 69? If anyone has done this, did you have problems with the alignment? Anyone have pics of this setup? I tried searching but didn't find anything.
www.diverserides.com
WTB 67-68 SWB, 350, Auto, Coil frame, Discs up front - PM me with details
smh292 is offline   Reply With Quote
Old 02-20-2007, 11:42 PM   #2
powell72
powell72's Avatar
Re: Airbags up front with drum brakes?
I can't imagine any issues, you just wouldn't get as low as you would with disk brake drop spindles. I saw a bagged drum brake truck on ebay a couple weeks ago.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-20-2007, 11:43 PM   #3
st1x10
st1x10's Avatar
I don't see y you couldn't. ***************** sells the front brackets for 67-87 chevy pickups. Why do you want to keep the drums up front?
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 02-20-2007, 11:57 PM   #4
smh292
I am concerned that the bags would lower the truck too much at ride height to be able to get a proper alignment - Kinda like cutting too many coils out of a spring. I don't want to kill my tires. I have a set of 2600's laying around and I don't want to spend the cash at this time to convert to discs. I'm just trying to find out if anyone has done this and gotten their truck aligned ok. I only plan to take the truck to local cruises so I'm not concerned about the drum brakes
Old 02-21-2007, 01:33 AM   #5
SCOTI
SCOTI's Avatar
Trucks w/bags & dropped spindles align ok so you'll be fine getting it aligned w/bags & stock spindles..... regardless of front brake type.
*EDIT* Unless of course you run the bags @ low psi/half the recommended ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-21-2007, 06:48 AM   #6
pkj
it works for me. pm farmtruk he has pics of mine set-up before i cut the cup and lowered another 1-1 1/2 inch. i cant post pics.
pkj is offline   Reply With Quote
Old 02-21-2007, 10:48 AM   #7
smh292
Does anyone have pics of their trucks with only bags upfront and in back with everthing else stock? I'm curious to see what the ride height would be and how low it would sit without modifying anything but swapping out the coils for bags in the front and rear. I'll pm farmtruk, thanks guys
Old 02-21-2007, 01:03 PM   #8
wannabeburbowner
wannabeburbowner's Avatar
I'll be putting my front bags on soon, (when the weather breaks, hopefully within a week or 2). I'll post pics when I get it done, it will be all stock with just bags put in place of the coils. No notch out back and with plates and cups in the front.
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 02-21-2007, 04:34 PM   #9
jimmydean
jimmydean's Avatar
Front bagged with 2.5 drop spindles and unmodified Suicide Doors cups.
Up:
Down:
Ride height is somewhere in the middle. Figure you can cut the front cups down enough to get that low with stock spindles.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-25-2007, 08:10 PM   #10
jeff1vol
jeff1vol's Avatar
Be careful. I just finished up the newest bag kit
from AirRide Tech on my '68 with drums all around. I had some slight modifications to the lower a-arm and aftermarket sway bar. The a-arm bump stops had to be removed for proper fit/travel. The aftermarket sway bar ends had to be ground to accomodate travel as well. If you have the proper tools you shouldn't have any problems. Better to be safe than sorry. Make extra sure that there are NO issues with sharp edges coming in contact with the bags through the entire range of motion. Good luck, you'll really enjoy them once they are in!
jeff1vol is offline   Reply With Quote
