Old 08-29-2002, 11:23 AM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
H-pipe, balance pipe place ment???
I just bught new headers for my truck and wile i was working on the exhaust i thought i would put in a H-pipe. My only questions is that where should i put it? Right after the headers, further down the pipes or what? Any help would be nice. Thanks Guys
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 08-29-2002, 11:48 AM   #2
jeremy martin
H- PIPE
HOTROD929
I HAVE HEARD THAT IF YOU RUN YOUR TRUCK AND PUT SOME SPRAY PAINT ON YOUR EXHAUST AND WHERE IT STARTS TO BURN OFF FIRST THAT IS WHERE THE H-PIPE NEEDS TO BE PLACED. I DONT KNOW IF THAT IS CORRECT JUST WHAT I HEARD. JEREMY
70 lwb 2wd
64 bug
00 silverado 4x4
00 Impala
"SECOND PLACE IS JUST THE FIRST LOSER"
jeremy martin is offline   Reply With Quote
Old 08-29-2002, 12:29 PM   #3
HotRod929
HotRod929's Avatar
Thats very interesting. I never herd of that before. Any other ways anyone? Thanks Jeremy.
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 08-29-2002, 12:47 PM   #4
dion
72 Cheyenne
dion's Avatar
Close to the headers.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 08-29-2002, 12:48 PM   #5
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
from what i here as close to the headers as possible
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 08-29-2002, 02:37 PM   #6
RON WOODGEARD
Resident Young Old Dude !
What JEREMY told you is the way it's supposed to be done, Even though sometimes there is something in the way of doing it, like the tranny,crossmember etc. The reasoning being it's the place where the most backpressure is swirling,IE: building heat.
This came to me from a friend that builds custom exhaust for race cars and streetracers.
RON WOODGEARD is offline   Reply With Quote
Old 08-29-2002, 03:52 PM   #7
HotRod929
HotRod929's Avatar
Thanks RON WOODGEARD. what kind of paint should i use? Will just like regular black spraypaint work? I beat it smells pritty bad for a while when the paint is getting burned off.
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 08-29-2002, 03:54 PM   #8
E.R. Leonard
Jermey has it. It is not as close to the headers as possible. I think you will find it to be 12-18" from the collectors.
67 C10 LT1 project step side
68 C10 250 short step side original
69 CORVETTE CONV 427, 4spd, 6-pak
99 CORVETTE CONV
78 chevy 2wd blazer
Angleton, Texas
E.R. Leonard is offline   Reply With Quote
Old 08-29-2002, 05:22 PM   #9
RON WOODGEARD
Any paint except HIGH HEAT.
I also agree it will be a foot to a foot and a half from the collectors.
Old 08-29-2002, 06:03 PM   #10
slam33
slam33's Avatar
Jeremy Martin is right. Thats what all the test have shown to work. It doesn't have to be a lot of paint, just hit it down one side of the pipe, run it, mark it, cut and weld. Then go back with some laq thinner and take off the rest of the paint
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-29-2002, 06:24 PM   #11
HotRod929
HotRod929's Avatar
Any particular color easyer to see or does it not matter at all?
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 08-29-2002, 11:02 PM   #12
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Talking
FLOURECENT!!!
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 08-29-2002, 11:17 PM   #13
Shane
Shane's Avatar
The paint method is the way that the old guys used to determine the length of "drag pipes" on Harleys. Back then you couldnt buy aftermarket exhaust that were already "tuned" to the correct length. They would paint a light coat on .... fire up the engine....ride around till the engine and headers got hot...shut off engine....let cool.....and then trim the tubes to the length where the paint burnt off. (told to me by my grandfather - an Ol' Harley Head from way back in the Knucklehead days.... )
Supposedly, this is the point at which the headers were their most effective at scavenging exhaust gases.
Shane is offline   Reply With Quote
Old 08-30-2002, 01:43 AM   #14
68 with 350 TPI
68 with 350 TPI's Avatar
Noting wrong with the paint method as it does work.
But if you want a easy way to do it go and buy yourself a Ray tek heat indacator.
All you will have to do is hold down the button and find the hot spot on the pipes.
Pretty easy to get it right as the ray tek has a lazer pointer that shows you exactly where the heat is comming from.
Just thought I would share a clean and easy way to do it.
Ray Tek's are about 70-80$ and you can get them at any NAPA autoparts
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 08-30-2002, 03:08 AM   #15
CoryM
There is actually an exact temperature where you want the Hpipe to be. I dont know what it is offhand, but will find out. The way it *should* be done is to fine the correct temp, then using a temp gun find out exactly where it is on the exhaust and stick it in. Im sure the paint method is fine when you arent looking for every last .1hp.
Good Luck
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 08-30-2002, 03:45 AM   #16
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
This is where I put my "H" pipe in my 71 blazer.Since it's a 4x4 and has a transfer case this was the forward-most position I could place it.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
