Old 02-21-2007, 08:39 AM   #1
gundyfan
Fan shroud
I'm putting 1999 350 vortec in my 1972 swb I am keeping the one pulley system that came with it,only changing where the a/c compressor was and adding a non a/c pulley in it's place.I need to know what fan shroud do i use because i keeping the radiator that was made in 72 and it has original fan shoud attached to it,i know the fan shoud won't work because the fan the came with the 1999 vortec motor is like 19 inches so what fan shroud do i go with.I thought reading past post on this some said to use a big block shroud well i ordered on from brothers and that won't fit. so has anyone got any idea's or know what one will work? Thanks
gundyfan is offline   Reply With Quote
Old 02-21-2007, 03:17 PM   #2
j@bt
Re: Fan shroud
are you keeping the 72 rad. or are you putting in the 99 rad? also have you thought of doing electric fans.
j@bt is offline   Reply With Quote
Old 02-21-2007, 03:42 PM   #3
gundyfan
Re: Fan shroud
i'm putting the 72 radiator in.
Old 02-21-2007, 04:59 PM   #4
neonlarry
neonlarry's Avatar
Re: Fan shroud
When you say one pulley system do you mean serpentine belt system? How big is the fan (diameter and blade count).
With my serp setup and 7blade fan I used a BB shroud.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
