Old 02-21-2007, 09:47 AM   #1
fade94
fade94's Avatar
Removing windshield question
I have a good windshield in my truck. However, I want to remove it to paint the cab and replace the weatherstripping. Anybody done this? What was involved? Where did you get your weatherstripping and how was the quality?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 02-21-2007, 10:09 AM   #2
Sammy
Re: Removing windshield question
Use a utilty knife or sharp durable knife cut the entire inside surface of the lip inside the cab. Carefully w/ helper push from the inside out starting at a corner. As far as windshield seals any of our vendors on site have good quality stuff. I used GMC Pauls seals. Beware of some that are discounted from e-bay I think you sorta get what you pay for. Especially if your planning on reinstalling the trim piece. They are sorta pain to mess with. Installation of the windshied is described well in the FAQ section.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-21-2007, 10:16 AM   #3
fade94
fade94's Avatar
Fortunately, mine is chrome free. Thanks for the info. I get a lot of stuff from GMC Pauls. My roll pan came in last night.
Old 02-21-2007, 10:16 AM   #4
zacut
67 chevy SWB Fleetside
Someone posted and easy 25 minute removal a couple of weeks ago, with pictures. I think it is listed in FAQ.
In short they used a piece of 3/4" garden hose and 2 pieces of extension cord. They gradually pealed back the inside top rubber and inserted the hose inbetween the rubber and the metal cab, just to keep the rubber seal bent back. Do the same along the sides and use the extension cord for a spacer here. Then push gently and the windshield will pop right out. Make sure you have helper on the outside to catch it, and I would recommend placing a blanket on the hood for padding.
This is supposed to be much easier than cutting it out.
67 Chevy C10 Short Wide
350/350 ... Front Discs ... ECE Lowered 2.5/4
Vintage Air ... Oak Bed Floor ... Painless Wiring
Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake
Ididit Column ... VDO guages
zacut is offline   Reply With Quote
