Old 02-21-2007, 06:32 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
brake light cuts emerg flashers?
I'm not sure if this has to do with my wiring the fender lights as blinkers (which i've gotten several props on doing), but if my emerg flashers are on and i press the brake pedal, i lose all running lights. Did i lose a ground somewhere other than on the fender lights?
everything else works fine- blinkers and brake, emerg only, brake only, running lights and blinker, running lights and emerg
magnethead is offline   Reply With Quote
Old 02-21-2007, 09:28 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: brake light cuts emerg flashers?
Brakes stopping the hazards is normal isn't it?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-21-2007, 10:26 PM   #3
magnethead
magnethead's Avatar
well it doesn't shut them off, it only makes ALL the running lights go out- including the ones on the roof i believe (even though they don't flash, they're still wired factory). Once i let off the brake, they start flashing again. I have the fender lights wired with the front markers so i dont think they're any part of it.
Old 02-21-2007, 11:31 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
That's what I remember but my truck is stripped so can't check it out.
________________________________
Why are you wiring all the marker lights to flash ? If you don't mind me asking.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-22-2007, 09:16 AM   #5
magnethead
magnethead's Avatar
I only appended the fender lights since i have a short tongue enclosed trailer and my normal tailights are impossible to see with it hitched. the roof lights are still factory wired; they don't flash. But even so, they go out if the brake pedal is pushed with flashers on.
Old 02-22-2007, 12:03 PM   #6
dswancutt
If I recall, the hazard lights should stop flashing when the brake is applied, but not cut all the lights.
dswancutt is offline   Reply With Quote
