Old 02-21-2007, 07:12 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Booster Rod Question
Ok I scored a 3/4 ton booster and master cylinder on ebay and the guy didn't put the plunger rod in the box. Now he can't find it. It's the one that goes between the booster and the MC. I don't believe the one from my 1/2 ton set-up will work so where can I get one? TIA......
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 02-21-2007, 08:12 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Booster Rod Question
How long do you think it needs to be? I have a rod in a Power break unit that wont fit my truck. Do you know how to measure what you need? I can look at mine with the MC off and tell you how to do measure it.
LMK
If it’s special I can probably make you tomorrow.
But I think the half ton will work. JMO.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-21-2007, 08:59 PM   #3
Draggn66
Draggn66's Avatar
LMK
s/t
I'm not sure how to measure it. I think I read somewhere here that the 1/2 ton is longer. Maybe things will be a bit clearer tomorrow but right now I'm kinda stumped
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 02-21-2007, 10:07 PM   #4
Sport/Truck
Sierra Grande Club
I took some pictures and measurements, the rod length is 2.5 x .365 with it in the hole (it’s in the wrong way, but didn’t change the measurement) is was .250 below the surface.
I don’t know what year Chevy this was off of but it’s newer than ours.
See what you get and that should tell us what you need.
If you need a shorter one I can put mine in a lathe and turn it down for you.
LMK,
s/t
Old 02-24-2007, 10:18 AM   #5
Sport/Truck
Sierra Grande Club
Randy, did you ever get yours measured??
LMK
s/t
Old 02-24-2007, 10:50 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the problem is, it needs to be adjustable, to make up for all the variables on the master cylinder makers. I've had to adjust that rod both times I had replaced a master cylinder on on of these boosters.
The one I have here, has a mushroomed head theat measures exactly one inch across, with a perfectly flat surface. This end goes into the booster.
Totally extended, I got 6 3/8 inches, and totally screwed in, right at 5 3/8 inches.
Old 02-24-2007, 12:04 PM   #7
Draggn66
Draggn66's Avatar
Board member Mac measured one for me and said it's 2.486" long and .365" in diameter. The M/C end is radiused to .100" of the length but has a .125" flat in the center. Not really sure how to measure what I need when they are connected
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 02-24-2007, 12:20 PM   #8
Sport/Truck
Sierra Grande Club
Sounds like your 1/2 ton can be made to work pretty easily.
s/t
Old 02-24-2007, 12:57 PM   #9
jimi121v
While we are on the booster subject. I have a 72 CK10, and was wondering if the dual diaphram booster from a 20 will work with all the 10 harware.(mounting brackets, push rod, mastercyl, etc.) Can I buy a new booster for a 20, and bolt it up to the 10. It has a new mastercylinder on it now.
Thanks, Jimi
jimi121v is offline   Reply With Quote
