Old 02-21-2007, 10:34 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
charcoal evap canister
How many of you removed the charcoal evap canister? I’m wondering what effects this may have.
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-21-2007, 10:50 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: charcoal evap canister
If you remove it, the vapors from the tank will be vented into the engine compartment...that might not be a good thing. Why do you want to remove it?
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 02-21-2007, 10:54 PM   #3
hvychve
To The Levy
hvychve's Avatar
charcoal is inside the cansiter and they over time loose there ability to store vapors, by removing the canister would only allow vapors to be emmitted to atmospher via the hose that hooked to canister , you will have no ill affect of any kind by removing this can, if you have smog / emssion laws (which I doubt you do) than you will run into issues there, If the can has good charcoal and has the ability to absorb vapors, leave it on, its not hurting a thing, it actual will benefit you a little, the vapors that are stored , will than be pulled into engine to burn, this to me is fuel efficient. so its your choice.
hvychve is offline   Reply With Quote
Old 02-22-2007, 01:22 AM   #4
cooters
they usually get pluged up after years so i remove mine completely
cooters is offline   Reply With Quote
Old 02-22-2007, 01:49 AM   #5
brak
brak's Avatar
you can replace the charcoal element in the canister.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-22-2007, 07:58 AM   #6
Sport/Truck
Sierra Grande Club
Can I get one at any major auto parts store?
Can someone show how it should be hooked up? I’m not sure if mine is correct, the hose that goes to the carb. ties into the hose from the valve cover to the large fitting on the front of the carb.
s/t
Old 04-09-2007, 10:40 AM   #7
MiniD
Is this the only vent for the fuel tank? I'm wondering if it's possible to plug the line that goes to the cannister when removing the cannister instead of just leaving it open.
MiniD is offline   Reply With Quote
Old 04-09-2007, 11:25 AM   #8
fosheec
fosheec's Avatar
I took my charcoal canister off and plugged the line. Just be sure that you have a vent gas cap to prevent vapor lock. Its no different that the pre-canister trucks.
Caleb
fosheec is offline   Reply With Quote
Old 04-11-2007, 10:30 AM   #9
MiniD
I bought what I was told was a vented cap and plugged the line. I ran the truck for 15 minutes last night without problems, but today it wouldn't start (usually fires right up cold) until I pulled the gas cap off. It seems the fuel sucked back into the tank.
What year did they start with the sealed cap? Seems I need a gas cap for an earlier truck.
Old 04-11-2007, 10:37 AM   #10
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
i took mine off and just cut it at the steel line. No problems yet after five years.
Justin
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 04-11-2007, 10:39 AM   #11
farmerfred
Not to hijack this thread, but I've been wondering where the canister should be. I don't see it in the engine compartment, although the PO could've removed it. Is it behind the seat?
1972 C-20 350
farmerfred is offline   Reply With Quote
Old 04-11-2007, 10:41 AM   #12
MiniD
It should be mounted on the passenger side in the top corner of the core support/fender connection (two bolt holes side by side going from the core support to the fender).
Old 04-12-2007, 04:55 PM   #13
farmerfred
Below the battery tray, MiniD? I'll have to look more carefully--if the rain ever stops.
1972 C-20 350
Old 04-12-2007, 04:59 PM   #14
MiniD
Between the battery tray and the fender where the core support bolts to the fender (upper two side-by-side bolts).
Old 04-12-2007, 05:22 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's on 71/72 only, so if you have a 70 or older, you'll never find it.
I see no reason to remove it personally. It stores and sucks the vapors from the fuel, and then burns it. It's kinda like a PCV, no drawbacks at all.
