Old 02-22-2007, 01:05 PM   #1
Has Anyone Installed a 4L69E or 4L80E in one of these trucks?
I have a 4L80E from a vehicle that had a "stand-alone" ECM just to operate the tranny.I`m looking at ways to drive the speedo.
Old 02-22-2007, 02:19 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Has Anyone Installed a 4L69E or 4L80E in one of these trucks?
Put an electronic speedo in it. These are pulse driven. I have heard there is a conversion but not sure, giveAuto meter a call. I have one to put in a truck but have not gotten that far yet, sorry not more help!!
70rs/ss is offline   Reply With Quote
Old 02-22-2007, 06:06 PM   #3
meathead95
computer illiterate
meathead95's Avatar
i believe year one has a box to convert from electric to cable driven for around 200$
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-22-2007, 06:06 PM   #4
meathead95
computer illiterate
meathead95's Avatar
what did the trans come out of?
72 2wd blazer
72 swb 4x4
Old 02-22-2007, 08:11 PM   #5
Well,I didn`t want to say`cuz I want it answered here.But,if you promise not to tell I`ll say it real quiet...a`91 3/4t 4wd diesel Suburban and I want to use it in a shortbed K/30 project.It`s the same deal 2 or 4wd.
Old 02-22-2007, 11:50 PM   #6
Bob Moore
I also have the 4L80E but not the one you have. I recall 2 vendors making the speedo drive. Unfortunatly I do not recall who they are. One cast a whole new tail piece while the other cut and welded a drive in place. I think the welded job was Art Carr Transmission.
My trans came from a van and I got ALL the wires and devices. I am not looking forward to hooking it up(paying $1100-1500 for harness) when I probably have everthing I need already.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-23-2007, 12:02 AM   #7
I wonder if I could use the speedo from the donor and keep the system "as manufactured."Maybe I could still use my stock face.
Old 02-23-2007, 12:34 AM   #8
70rs/ss
70rs/ss's Avatar
That would be the easier/cheaper way. I though there was an adapter out there to convert, but as usual $$$ is the factor.
Old 02-23-2007, 08:59 AM   #9
billyjo
Junior Member
billyjo's Avatar
So is it going to be in a 2 wheel drive because if it was in a 4 wheel you could just use the cable coming off the transfer case.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 02-23-2007, 09:15 AM   #10
Does the NP241 have a cable bung?Yeah Steve,I`m trying to use up what I have,not goin`for the high-dollar thing.
Old 02-23-2007, 10:30 AM   #11
billyjo
Junior Member
billyjo's Avatar
I didn't consider a NP241 but I know that the NP205 has the cable.
Old 02-23-2007, 12:25 PM   #12
Yeah,I want to swap both from a`91V2500 Suburban I`m parting.I have NP205s,but just 70-72 vintage.Thanks,though.
Old 02-24-2007, 02:27 PM   #13
Givin`this another whirl.
Old 02-25-2007, 12:54 AM   #14
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Abbott-tach dot com has a $300 unit to convert the speedo.
low'n slow is offline   Reply With Quote
Old 02-25-2007, 07:55 AM   #15
Thanks,there,low`n slow.That sounds pretty swirthy,since I have everything else already.
Old 02-25-2007, 01:12 PM   #16
Is that Abbott Enterprises in Pine Bluff,AR?
Old 02-25-2007, 02:45 PM   #17
low'n slow
low'n slow's Avatar
That would be it. It is called the cable-x. I am going to use one too. I was going to use a 700 inplace of my turbo 350, but ran across a good price on a 4L60e. Since I have an 94 LT1, it will be nice to have all the extra electronic goodies working as well.
Old 02-25-2007, 03:28 PM   #18
That`ll be sweet,LT1/4L80e.Thanks again for the lead.
