Old 02-22-2007, 01:13 PM   #1
williamt
68 just like me
williamt's Avatar
ok first question
hello all I am new here and have the first of what I am sure will be many questions. I have a 68 longbed fleetside and was trying to remove the guage cluster the other night and could not get the choke knob off .Is there a trick to this or am I just missing some thing. I will try to post a pic of my truck tonight I don't have any here at work.
williamt is offline   Reply With Quote
Old 02-22-2007, 01:16 PM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: ok first question
Welcome!
If I recall.. I think that one screws off.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-22-2007, 01:23 PM   #3
williamt
68 just like me
williamt's Avatar
I tried holding the stem with plyers and turned maybe it is stripped. thanks
Old 02-22-2007, 01:28 PM   #4
68speedalert
Semi-Senior Member
68speedalert's Avatar
A small set screw sideways on the knob. Turn the knob or look around until you can see it. A small pocket screwdriver will get it out.
After the knob removal, the bezel unscrews from the dash.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 02-22-2007, 01:31 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The choke should unscrew off the shaft, just pull it out and hold it with pliers.The wiper knob should have a little set screw on the side. If you have trouble with the tight switch knob, It has a button on top of the switch that has to be pressed to release the knob and shaft.
sneakysnake is offline   Reply With Quote
Old 02-22-2007, 04:00 PM   #6
williamt
68 just like me
williamt's Avatar
it looks like mine has been changed so I will try again tonight .thanks I learned the leason on the light switch the hard way cost me 12 bucks oh well live and learn. I just noticed your wash/wipe is where my choke is.
Old 02-22-2007, 05:47 PM   #7
68speedalert
Semi-Senior Member
Originally Posted by sneakysnake View Post
The choke should unscrew off the shaft, just pull it out and hold it with pliers.The wiper knob should have a little set screw on the side..
My bad....been too long since I messed with the choke cable. But I KNEW I messed with that set screw...
Old 02-22-2007, 09:17 PM   #8
grayw0lf
Welcome to the best board around!
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 02-22-2007, 09:21 PM   #9
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
