swapping body parts between frames
Got a question about swapping parts. I have an opportunity to buy a 1985 3/4 ton GMC 4X4. I currently have an 85 GMC 1/2 ton 2WD. Is it possible to swap the front fenders and cab without mods? DO transmission type matter. The 3/4 ton is auto, the 1/2 ton is manual. I will retain the auto trans and just not use the pedal for the clutch. Is it difficult to work in the transfer case shifter. I assume I could do what I have done in the past and just cut out the hump and weld it into mine?
thnaks.
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305 5 speed, 3.42 rear 2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L 1999 BMW 528i |
| Bookmarks |
