Old 02-22-2007, 02:37 PM   #1
Chevy_Man
Tightwad
Chevy_Man's Avatar
Anyone have this Problem??
I have been tearing into my cab and have found this and more...Has any of you had this problem and what have yall done about it?
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 02-22-2007, 03:22 PM   #2
sleepyboy
'69 Step
Re: Anyone have this Problem??
The more you dig, the more you will find. Mine was like that, keep working.
sleepyboy is offline   Reply With Quote
Old 02-22-2007, 03:31 PM   #3
hvychve
To The Levy
hvychve's Avatar
Those darn cowl's , they let so many leaves and debri in and this is usually where it is all trapped for years and years to eventually cause what you have going on there. I installed a stainless steel mesh under the cowl and am glad I finally did, who knows how bad it looks on the inside, but nothing showing on the outside yet, good luck and dont stop there.
hvychve is offline   Reply With Quote
Old 02-22-2007, 03:51 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Cancer the #2 cause of death.LOL Good luck on your repairs
sneakysnake is offline   Reply With Quote
Old 02-22-2007, 04:26 PM   #5
Chevy_Man
Tightwad
Chevy_Man's Avatar
I will have more pics tonight what it looks like on the inside....lol ouch!!!!!
Eric
55 Chevy 210
72 Chevy LWB
84 CJ 7
Old 02-22-2007, 04:32 PM   #6
jimmydean
jimmydean's Avatar
Can you get to that with the fender off?
My driver side is good, but my passenger side is nearly gone. I need to get on the back side to fix it before i do new kick panel speakers.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-22-2007, 04:46 PM   #7
jdhcth
jdhcth's Avatar
YEA! And every time it rains all the water from the windshield goes right down there. I took the cowl off and siliconed from the top, sprayed rust converter on from the inside and cross my fingers. Last rain, still had a little drip through but was a great improvement. Took my shop vac and stuck down into the fender, looked like a freakin' squirrel nest in the vac's canister, leaves from the kind of trees I don't even have around.
Just a bad design. Good luck.
JD
jdhcth is offline   Reply With Quote
Old 02-22-2007, 04:58 PM   #8
whatnow123
whatnow123's Avatar
Everyone has or had this problem If they own a 67-72 truck. The trucks are prone to rust due to the cowl area.
You are not alone.....
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 02-22-2007, 05:22 PM   #9
70rs/ss
70rs/ss's Avatar
No what is the rusty brown stuff?
Just yankin your leg, I have seen it on trucks from back east but here in AZ, I'd be willing to sell that one and come out west to get a better one and not have to fix it, but thats, me.
70rs/ss is offline   Reply With Quote
Old 02-22-2007, 09:38 PM   #10
Chevy_Man
Tightwad
Chevy_Man's Avatar
Well after doing some cutting and looking this is what i found, now i know what is behind the cowl vent that you are not able to get tooo.. Now the questions is do i change it out with another vent kick panal or to i cut it out and plate over it. The fun begins
55 Chevy 210
72 Chevy LWB
84 CJ 7
Old 02-22-2007, 10:08 PM   #11
Eddie H.
Eddie H.'s Avatar
About 20 years ago I decided to do a "temporary repair" on my 69 that was rusted out in those same areas. I opened them up, sand blasted all the rusted areas down to clean metal, and fiberglassed over everything with a couple layers of resin and cloth. It has held up fine with no leaks or re-occuring rust. Probably better than It was originally since fiberglass won't rust.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-22-2007, 10:53 PM   #12
ChevyCrazy67
ChevyCrazy67's Avatar
Yep you gotta bad case of tha metal eatin termites there.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 02-23-2007, 08:48 AM   #13
Chevy_Man
Tightwad
Chevy_Man's Avatar
ttt
55 Chevy 210
72 Chevy LWB
84 CJ 7
Old 02-23-2007, 09:18 AM   #14
timcos
Chief Honcho In Charge
timcos's Avatar
I would imagine that there really is no reason for the cowl vents anymore. I do not even use mine. I may eventually cut them out, close them off and cuit the channel out (might save about 30 pounds). Then I can do the shaved cowl deal.
Or you could use the vent chamber for a speaker box and really give those kick panels a good use.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
