Old 08-29-2002, 03:31 PM   #1
sewanhaka62
1984 suburban rearend ????
hi
what rears are interchangable with a 2 wheel drive c10 suburban
1984
are regular trucks the same and what year range
thanks much
bob
sewanhaka62 is offline   Reply With Quote
Old 08-30-2002, 01:25 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Bob,
Any 73-87 truck or 73-91 Suburban, Blazer rear end will work. Heck you can even put a dually rearend if you want four tires!!
I would go for the older 12 bolt rearends over the 81+ 10 bolts. I swapped my stock 83 10 bolt for an older 12 bolt rear end. Gear ranges from 2.72 to 4.11 are available too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-30-2002, 08:36 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
dually rear wont bolt in because on those and on 4x4's the spring pad spacing is ony 40", yous is 42.5"
a 64-72 leaf rear wil bolt in under you truck, nut there are too problems with doing that: you must then use the 73-up Ubolts and plates, and also youl have to move one shock mount on one side only.
U joints may differ, maybe, depends on year and axe and yoke style. but conversion joints can be bought for anything nowadays
good luck
10 bolt ratios: 2.73(early to mid 80s mainly), 3.08(all years), 3.42(80;s and 90'), 3.73(unknown)
12 bolt: 2.76(not sure when), 3.07(all years), 3.40(around '77), 3.73(unknown)
Fast68Chevy is offline   Reply With Quote
