02-22-2007, 03:18 PM | #1 |
band adjustment on powerglide
Okay, i'm new to the powerglide type trannies and was wondering about the band adjustment...is this something I could do or something I need to take to a tranny shop to do...what does it intel?? I'm going to change the fluid and filter soon...the tranny has 44,000 miles on it...so I think it should be in okay shape. Thanks for any help.
I'm Your Huckleberry. You Ain't No Daisy. |
02-22-2007, 03:27 PM | #2 |
Re: band adjustment on powerglide
It's easy.70 inch pounds and then back off 4 complete turns (with the unit in neutral).Make sure you hold the locknut with a wrench to keep it from tightening up during the adjustment.It's been many years but I think it was pretty easy job.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
02-22-2007, 04:52 PM | #3 |
how do you get to the bands?? do you have to drop the tranny or just the pan or what? never done anymore than changing fluid and filters...installing a shift kit in a TH350 and clutchs on ford and dodge 3/4 tons
02-22-2007, 05:24 PM | #4 |
As I recall (very dimly),we wouldn't bother with the bands unless the RPMs rose just before the actual shift,or if the shift it's self was sloppy. And going by the manual,because I sure as heck can't remember,there is sometimes a need to "remove rear mount bolts from crossmember,and move transmission slightly toward passenger side of vehicle" to access this adjuster.
The adjuster is above the shift shaft,perhaps slightly behind.
