Old 02-22-2007, 06:26 PM   #1
bigblock69
Junior Member
700-R4 tail housing trouble
I posted yesterday and I got some of my questions answered; however, I have some left unanswered. I am putting a 454 in my 68 C-10. I am using a 700-R4 and an Early Classic transmission cross member. Problem is this. The tail housing is hitting on the cross member. No problems right, just use a spacer. Well I contacted Early Classic and asked if this problem has ever occurred before and there answer is “never heard of it happening before” why are hundreds of Early Classic customers having an outcome other than mine? I am using the correct 67-71 big block engine mount towers and the correct big block engine mounts. The engine and transmission were only sitting/not bolted down when I noticed the tail housing hitting. Could this have something to do with it? I have since pulled both eng and trans out to collect my thought on this. Any help would be greatly appreciated.
bigblock69 is offline   Reply With Quote
Old 02-22-2007, 06:30 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: 700-R4 tail housing trouble
I'm not sure if I understand your question... is it hitting the floor of the cab?
All big block trucks came with a "high hump" floor pan. You can tell if your truck has one by looking at the hump over the transmission. If it is bolted to the floor, you have the correct floor hump. If your floor is one single piece then it's a low hump floor and you should probably put in a high hump floor.
If this is your problem I (or another) can elaborate on adding a high hump floor, it's easy.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-22-2007, 06:33 PM   #3
bigblock69
Junior Member
It is hitting on the transmission cross member. The transmission mount is touching the cross member but, so is the tail housing. If I were to tighten the mount bolts it would probably damage/break the tail housing. Does this help at all?
Old 02-22-2007, 07:01 PM   #4
cdowns
cdowns's Avatar
have you tried reversing the crossmember
Old 02-22-2007, 07:09 PM   #5
bigblock69
Junior Member
It only fits one way that I know of.
Old 02-22-2007, 07:15 PM   #6
bigblock69
Junior Member
I included the pic of the trans mount in the last one. Figured I would include the eng mounts and towers. Any help would be much appreciated.
Old 02-22-2007, 07:37 PM   #7
bagged91
Out draggin'
bagged91's Avatar
What vehicle did your 700R4 come from? There are 3 different tailshaft housings for a 700R4. The one from the 88-93 C/K pickups should give you the most clearance. The Caprice version has and extra mount built into it and the F-body/Astro Van version has a mount cast into it for the torque arm. The housings are all interchangable... Hope this helps... I will be doing the same swap very soon. Tommorrow, if I get the time & the weather cooperates, I will take some pics for you (I have all 3 under a tarp )
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 02-22-2007, 07:54 PM   #8
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
I mocked up my drive line w/ sbc and 700r4. Not sure what my tranny came from, but it too was extremely close on my ece crossmember. Less than a 1/16 of an inch. I have been working on sheetmetal, but thought when I get back on the drive line, I would simply put a .250 shim plate under the mount. I don't see a problem with that. Just my opinion.
polevault1977 is offline   Reply With Quote
Old 02-22-2007, 08:12 PM   #9
bagged91
Out draggin'
bagged91's Avatar
Did a quick search on the net & found this... Hope it helps...
Caprice on LEFT--------- F-Body/Astro Van MIDDLE -------- C/K Pickup on RIGHT
92 GMC K1500 Burb
