02-22-2007, 06:38 PM | #1 |
Junior Member
The value of original
What is your opinion of the value of the original carb? I can find a couple with the correct number (Quadrajet) but I don't know if it really adds value in the long haul. I would like this truck to be as correct as possible without trying to make it showroom new...A LA Barrett -Jackson. It will be driven, but it will be clean...cost is about $500.00, and I could easily rebuild the Holley that is on it, but I am curious what the panel thinks.
Skip |
02-22-2007, 09:02 PM | #2 |
Re: The value of original
unless you have a numbers matching chevelle ss or 69 camaro pace car convertable !!! rebuild the holley
just my 2 cents Last edited by rage'nrat638; 02-22-2007 at 11:29 PM. |
02-22-2007, 09:33 PM | #3 |
Whatever you do,don`t toss them.I haven`t seem a replacement that`s better,yet.Whether it`s a high-dollar truck or not,if staying original is your thing that`s a good way to go.If anything on these trucks wasn`t good enough we wouldn`t have so many runnin`around for so long.I don`t think it has to be a car for originality to matter,either.At first with these trucks becoming classic the all-original highly optioned trucks were where the bucks was.But,that`s been lost in the mix with all the people that have gotten into them.You can find trucks with upgrades and aftermarket all over them all day long.The all-originals will always be the toughest way to go.
02-22-2007, 09:44 PM | #4 |
I AGREE
i am running a quadrajet on my truck. i love it i just would not spend 500.00 on a q-jet anyday. i upgraded mine to a hot tube converted electric choke carb no more devorced choke. Last edited by rage'nrat638; 07-12-2007 at 06:56 AM. |
02-22-2007, 11:06 PM | #5 |
Sierra Grande Club
How does that conversion work? I called around for one, and ive been told it wont work on my carb. It was suggested I get a qjet off a newer truck. Is this true?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-22-2007, 11:22 PM | #6 |
well this is the part to use for a devorced choke conversion
(THE ORIGINAL CARB) http://www.carburetion.com/quadrajet.asp Last edited by rage'nrat638; 07-12-2007 at 06:56 AM. |
02-22-2007, 11:45 PM | #7 |
GEARHEAD
IMO the original thing is hard too do because to make it worth the most money every single thing and I mean every single thing has to be original to make it worth while. That is so expensive in the long run that your almost afraid to drive it. If your gonna drive em like they were ment to be driven the original thing is way over rated. Don't get me wrong the original parts are all fine as far as that goes by all means, but when you see these so-called original resto's they are usually 100,000$ plus restos that will not be driven to any extent. JUst my .02
02-22-2007, 11:53 PM | #8 |
Go with whatever carb you like...
Even if the truck is mostly stock/original, i doubt that anybody woud give you grief for the carb. Even if you take your truck to shows, unless you are competing at concourse level, aftermarket carb isn't gonna hurt you, and depending on your setup, it might even gain you some points.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
02-23-2007, 12:50 PM | #9 |
"Trucks with Class"
I think you have a good plan to keep everything as stock as possible. Try to run correct type parts, even if the #s don't match. i.e. Run the correct type QJET, they work great and everything fits.
Good Luck & have fun! PS: I like hot rod trucks, too. |
02-23-2007, 12:58 PM | #10 | |
Semi-Senior Member
If so, I have a tip to make your choke work better. Remove the housing and plug the vacuum port between the carb and choke housing. On an everyday driver, the small amount of vacuum that it will still draw thru the choke housing will make the choke plate stay closed too long. At least that's been my experience here in Missery.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
