Old 02-22-2007, 11:00 PM   #1
setandreel
setandreel's Avatar
tranny and rearend ?
Hey all,
How can I tell which tranny I have 65 c10 3 speed only number I can find on the side is 3880211. and how can I tell my ratio on my rear end ? Thanks
Mike
setandreel is offline   Reply With Quote
Old 02-24-2007, 04:58 AM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: tranny and rearend ?
is it a auto or manual in 1960--1966 engs where 250s 283 and in 1966 was 327 trans missions where 3 on the tree speeds 4 speeds on the floor and the 2 speed automatic powerglide the 3 speed was a long gear box with 2 levers a 4 spped had 3 now i've seen 3 speeds with a over drive maening it has 4 spped but they called it a 3 speed with a over drive hope that helped
Rear end gears depends on what part of the country your from i've seen 299 gear in the cold states do to the snow and ice on the roads if you had a 373 you do a lot of spinning and sliding down the street and crashing into other cars not good on the gears
stsalvage is offline   Reply With Quote
Old 02-25-2007, 10:18 AM   #3
setandreel
setandreel's Avatar
Thanks stsalvage
Its a three on the coulmn saganaw I found out by the casing. The numbers on the ring gear are 3817778 11 41GM11 64 2 27 any idea? Maybe 4:11
Thank you
Mike
Old 02-25-2007, 12:14 PM   #4
72402
That's interesting, I wonder how GM knew what part of the country these vehicles were going to?
The numbers 11 and 41 indicate the number of teeth on your ring and pinion.
Dividing 41 by 11 gives you 3:73.
Frank
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
