Old 02-22-2007, 11:22 PM   #1
PumiceMan
Junior Member
PumiceMan's Avatar
Paperwork / Instructions for CPP disc conversion
Hey all,
I ordered and recently received the disc brake conversion for my 69 GMC (currently 6 lug manual drums) from CPP. Unfortunately it didn't come with any paperwork, and I thought it might be quicker to see if any of you may have something you could email or post. Scanning them in and sending 'em would be ideal. They do have a few instuction sheets for some of their stuff (online), but nothing that shows the new spindles, ball joints, rod ends, etc for the kit I have.
It's the full kit (6370SWBK-6D) complete with spindles, calipers, rotors, tie rod ends, ball joints, etc. If anyone has used a similar kit, I'd expect the paperwork is the same (stock height or drop shouldn't matter, nor should lug count). I did also get a new booster / master cyl / prop valve, but it came with the right papers.
What I'm after is how to replace parts in the future for wear, and which of these parts are actually stock parts for given year/model vehicles. For instance, I believe all the tie rod ends and ball joints are just 73-87 parts, but what about the calipers? What brake pads do I get? How about bearings, seals, etc? Are the rotors stock on something or are they custom made particular to this kit?
I'd also like to get any torque specs they may have put in the installation instructions, or if there were any other special instructions they may have had. I'm going to be pulling the old suspension off and maybe getting some of the new stuff on this weekend, so I'd like to get this as soon as I can. I realize chances may not be that great that someone has these, but it would probably be a lot faster than going through the original source. I may try calling them tomorrow anyway to see if they could email me or fax them.
Thanks!
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
Last edited by PumiceMan; 02-22-2007 at 11:25 PM. Reason: forgot to specify "online" for their instruction sheets
PumiceMan is offline   Reply With Quote
Old 02-23-2007, 09:14 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Paperwork / Instructions for CPP disc conversion
Here's a bump for you
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-23-2007, 09:30 AM   #3
chevybill
chevybill's Avatar
Call them back and ask for Javier (ha-v-air) if he still works there he is great help. They should mail you what you are looking for.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 02-24-2007, 11:15 AM   #4
PumiceMan
Junior Member
PumiceMan's Avatar
Thanks for the bump dave2953.
I did end up calling them yesterday with some questions (before I read these posts, so I didn't ask for Javier). The person I ended up talking to basically told me that most of the parts are stock for the 73-87 trucks. Upper & lower ball joints, outer tie rod ends, rotors, calipers, pads. The inner tie rod ends in their kit are stock to the truck you're putting them on, which is why they have the custom adjusting sleeves (old inner, new outer). The spindles are of course manufactured there, so there is no stock replacement, but the actual spindle shaft is the same as the 73-87 trucks, so if you need bearings, that's what you ask for.
As far as torque specs go, he said that basically everything in the chassis manual still applies. They were helpful on the phone, and told me if I had any other questions or ran into any problems during assembly to give them a call. I really don't know if they actually have paper instructions for the kit or not.
I spent most of the day yesterday getting the old stuff off. All original ball joints. First time most of that hardware's been unbolted since 1969!
68 Camaro SS
18 GMC Sierra SLT
Living the dream
