Old 02-23-2007, 12:07 AM   #1
BCOWANWHEELS
what are the differences between 3/4 & 1 ton
could you guys that know alot about the 3/4 ton and 1 ton single rear wheel trucks tell me what the differences are structurally & brakes etc. i know one will haul more than the other but is the 1 ton alot more h/d built ?
thanks again
bob in tn.
BCOWANWHEELS is offline   Reply With Quote
Old 02-23-2007, 05:02 AM   #2
Bob B.
Re: what are the differences between 3/4 & 1 ton
If you are just talking about '67 to '72 GM trucks, the 1 tons actually have a longer wheel base. The only 1 ton pickups built during these years are either 9 foot step sides or 8 1/2 foot Longhorn/Sierra Grande models. Generally speaking, the 3/4 tons had around a 7500# GVW, but the 1 tons could be anywhere from 7500# to 12,000# GVW. There were no dually pickups offered before '73.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 02-23-2007, 06:39 AM   #3
dwaite72lnghrn
The 1ton C30 have a much higher frame. The rear end in the c30 would always be an H072 in single wheel and could be H072/H110 in a dual wheel. Brakes are bigger front and back. All c30's have leaf springs. Looking at the frame the metal is a heavier gauge on the c30 compared to my K20.
The 3/4ton C20 would have either the H052(5200lb axle) or the Dana 60(5500lb axle). They could be coil or leaf sprung. That is just the basics.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 02-23-2007, 04:02 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yep, these are correct.
The wheel base on a 3/4 ton is 127 inch. There were a relitivly small amount of 3/4 ton longhorns built on the one ton frame, but, it is a one ton frame... so it's kinda like a 1/2 breed between a one ton and a 3/4 ton.
The one ton came in 133 inch, and 157 inch wheel base.
Taller and heavier frames, as mentioned.
all had rear leaf springs, as mentioned
there were no 4X4 one tons built by GM in 67 - 72.
brakes were larger, again, already stated...
basicly, the one ton was a little more stout, but, still, basicly the same truck.
Old 02-23-2007, 08:18 PM   #5
BCOWANWHEELS
thanks guys i,ve found a old 1 ton that is a little rough body wise but its whats under the body i want. i need a good workin truck and i think its the ticket. i,am thinkin 6 bt cummins, nv5600 trans and possibly a srw 14 bolt out of a more modern chevy. are the older rear ends better than the newer 14 bolts in the 1 tons ? also would a modern 14 bolt dually rear end fit.
bob
Old 02-23-2007, 08:33 PM   #6
dwaite72lnghrn
The newer 14 bolt rears I think are rated at 6000lbs. I don't think the spring pads line up with the springs on the old frame. The 14 bolts came in a semi-floating 3/4ton version and a full floating 1ton. The rears with duals were available in 2 widths. chassis cab had a narrow housing and the dually pickup beds had a wide housing. I've been thinking of a 14bolt swapout as the H072's are just getting to hard to get parts for. I don't want to be stranded on the road miles from nowhere and no place to get parts.
2009 HHR aqua blue
Dave & Jeanne
Old 02-23-2007, 10:24 PM   #7
ktgooch
SWB CLUB
ktgooch's Avatar
500 lbs
ktgooch is offline   Reply With Quote
Old 02-23-2007, 10:38 PM   #8
earl87gta
earl87gta's Avatar
BCOWANWHEELS, I know where their are a few of them here in kingsport I drive by them every day. Im always wanting to stop in and see if they will sell me one. from the road it looks like they have 3 72 1tons. For the rear if you go to a new DW axle you will have to move the spring mounts but the SW 1ton is the same.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-23-2007, 10:42 PM   #9
skchevota
skchevota's Avatar
Originally Posted by ktgooch View Post
500 lbs
skchevota is offline   Reply With Quote
Old 02-23-2007, 11:49 PM   #10
BCOWANWHEELS
i,ve got a srw 14 bolt full floater rear out of a cucv military truck. glad to hear it will fit. i need a rear easy to get parts for also. this will be an over the road rig. wonder whats the lowest ring and pinion ratio i can get for the 14 bolt, 3.55 ?
Old 02-24-2007, 03:28 AM   #11
earl87gta
earl87gta's Avatar
I would think you could get one that low I have a 14blt I use for parts with a 4:10 the one you have should have 4:56s ive never seen a 3:55 in one but I have seen3:55 in the dana 70s
Earl
Earl
Old 02-24-2007, 10:59 PM   #12
BCOWANWHEELS
well i did it. i bought the 1972 c30 truck today. 700.00 minus the 350 engine and 4 speed trans. i,am going to install a 6bt cummins and a nv5600 or turbo 400 with a gv overdrive unit. and that ho72 rear is going to be pulled out also. if anybody needs it contact me. the truck has 85,000 original miles on it.
i finally got me a seroious tow rig in the works. wonder what the dana 70 rears came out of that would fit this truck in srw.
bob
Old 02-24-2007, 11:05 PM   #13
earl87gta
earl87gta's Avatar
cool you going to make it a 4x4 or keep it 2wd. Im puting a 6.2 in my burb soon I was going to use a 6bt but just out my price range right now.
Earl
Old 02-24-2007, 11:18 PM   #14
BCOWANWHEELS
i,am going to keep it 2 wd , 6bt cummins & nv5600 or th 400 with GV o.d. & SRW. I NEED 5 -16" STOCK WHEELS
Old 02-24-2007, 11:55 PM   #15
earl87gta
earl87gta's Avatar
If you go with an auto I would go with a th400 I had an 92 with a Cummins and it went threw 2 transmit ions with less then 150k on it. I ended up selling the truck and going to a D-max. Does the GV O.D. require the tail section to be removed off the trans so that you could use a 4wd trans.
Earl
Old 02-25-2007, 11:11 PM   #16
BCOWANWHEELS
looks like to get my rpm,s right at 65 & 70 mph i,ll have to go nv4500 or nv5600. alot of work just to get the mpg but in the end it will be worth it i recon........
Old 02-26-2007, 01:54 AM   #17
earl87gta
earl87gta's Avatar
have you seen this write up yet its close to what you are wanting to do.
http://coloradok5.com/forums/showthread.php?t=121702
Earl
Old 02-26-2007, 01:59 AM   #18
earl87gta
earl87gta's Avatar
Does the 5600 have the trouble the 4500 dodge has . the 4500 had a trouble with 5th gear for some reason. I read an artical on it once. didnt make since to me the chevy didnt have the same trouble. The 6 speed would just be way cool.
Earl
