<>AnoTheR MoTor QuEstIoN<>
OK so I have a 1968 327 with 1968 327 truck heads, can I put an 1987 throttle body injection system on it I.E intake manifold throttle body, all the censors, and then bolt in a inline electric fuel pump. or is there something special inside the t.b.i motors
Re: <>AnoTheR MoTor QuEstIoN<>
I am no pro on this, but I was tol before that the acual "V" or degree of the sbc V8 was changed between your old motor, and new intake setup. Just my 2 cents, I may be waaaay off on this one.
Oh, and happiness IS a belt fed weapon, ever though I have not had the chance to try one out! Last edited by PrerunnerRob; 02-23-2007 at 02:28 AM. |
Hollister, CA.
![]() Join Date: Sep 2006
The best thing to do would be to install the TBI onto an OG manifold...you would need a 2-barrell intake though. You would have to fab up an adapter plate.
The MAP sensor and coolant sensor would be no bid deal. Your gonna need the O2 sensor in the exhaust somewhere. Take some work, but it would work good John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
If you can get the heads from the 87, then the TBI manifold should bolt on. Of course then your accesories won't bolt to the front of the head. John may have the best idea with a 2BBL manifold. Good luck.
glenn |
I have the entire 87 motor but I think its locked up! the '68 heads on the 327motor are 64cc truck heads w/ no accesory holes so I would be in the same boat I'am now
Slots go on anything!
If you are wanting to go efi, you could probably put a Holley Pro-jection 2bbl unit on for about what you would spend to adapt the 87 system.
how is that holley efi set up is at the minimum 650, I have the entire 87 tbi motor???
you don't need a 2bbl manifold they make adaptors for the 4 bbl so you can put it on any intake you want too, they are like $40 if i remember correctly.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
#9 | ||
You can use the TBI intake by making the 4 center holes oblong to match up with the earlier heads. Only the 4 center holes are at a different angle, starting in '87 with the center bolt valve cover type heads. |
#10 | |||
Hollister, CA.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 02-24-2007 at 09:52 AM. |
dude you were suppose to give me a price on that complete setup man!!!!!
so lets recap the cheapest and easiest way to put this tbi on my 327 would be to use the tbi manifold and oblong the center holes and use all the censors off the tbi and run a ruturn line (which wont be hard since i'm going to do the blazer tank conversion). on a scale of 1-10 how hard is this conversion? am I going to be balls deep on this one?
#13 |
I did it on my 65 it's not really hard about 7 on the scale. Just remember to hook the vss up.
65 c10 tore apart 70 c10 305/350th |
#14 |
and what does vss stand for again??
#15 |
Vehicle speed sensor. Before you dive into this, you might want to do a little reading on how the TBI works. Jaguars that run has a couple of really good books on fuel injection swaps, and I think most of the really good FI swap knowledge is on their website. The way it is written makes it very easy to understand. If you can swing it, I would suggest an aftermarket wiring harness. The factory harness will give you a bunch of extra crap you dont need, and it is a pain in the balls to get out of the dash.
#16 |
already have it out and neatly coiled up I also have the ecu to match sitting by it. I have worked on tbi's before its just been a while. and wondering how common this is. does anyone know where i can have the milling work done to the manifold!?
#17 |
Just take a drill after it that's what i did worked good. And what ecm number do u have?
#18 |
not sure to be honest with you it all came out of a 1987 suburban! So the drill worked ok? just oblong the holes so they line up and did you get a good seal on your manifold?
#19 |
It's running good so i guess its good and sealed. lol Look on the ecm there should be a sticker with some nummers like 1227747 on it.
#20 |
hey which distributer did you use chevy283? the hei with the coil in the cap or the tbi dist. with the remote coil, and when you bore those manifold holes what did you do about the heads of the bolts sitting flush?
#21 |
I use the tbi dist with the remote coil. And here's a good idea on the maniford holes http://www.persh.org/pickup/TBI%20Intake%20Manifold.htm
#22 |
yup I have the site saved on my fav's just wondering if that was what you did too! thanks
#23 |
No i havn't done anything to mine yet. that's just what im going to do someday.
#24 |
ok well another move in housing has forced me too scrap the t.b.i idea. no room and to time to convert it must get it going quickly. so what do you think the harness, ecu, distr. throttle body, manifold, and most of the censors are worth. Lets say you were going to buy one how much would you pay?
