Old 02-23-2007, 09:08 AM   #1
66shortwide
Changing Floor out
Guys,
I need to replace the rusted out floor, rockers, cab corners, and floor supports on my 66 and have run into a small problem. How do I support the cab to keep everything straight while I cut out all this metal? I plan on removing the cab from the frame, but I'm afraid the whole thing will twist, and after I replace all the metal nothing will fit right.
I'm looking for any kind of suggestions as I am ready to remove the cab.
66shortwide is offline   Reply With Quote
Old 02-25-2007, 02:38 PM   #2
rodnok1
rodnok1's Avatar
Re: Changing Floor out
The best way would to weld supports across door openings and across the cab, but I would make sure the doors line up before you do it, it probably has already moved around some with alot of rot.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
