blower switch
What is the STOCK location of the blower switch on a 71 truck? I have looked at dozens of trucks on here and evilbay and have not seen where they are mounted, heck most of the time I don't see one at all. Mine is under the heater controls screwed to the dash. My truck does not have a/c. Thanks in advance.
-Scott- |
The Older Generation
Re: blower switch
Original ones are part of the heater control unit located in the dash. Connected to the levers. LockDoc
Re: blower switch
Ok, I rebuilt my levers and noticed some type of an electrical connector attached to the assembly. That's where it goes? How do you move the lever to adjust the fan speed? I don't temember seeing anywhere to attach the switch to a lever. Does anyone have a pic?
-Scott- |
Firefighter
Re: blower switch
The switch has an arm with a pin on it, it bolts to the side of the control with the plug facing out and the arm going in toward the levers the center lever has a "track" that the pin fits into it also has a plastic bushing that fits over the pin.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Re: blower switch
I do remember the "fat" lever having a groove in it and replacing a plastic bushing. I guess I just didn't realize that was the old switch "in pieces". The PO I guess just screwed the switch to the dash and I didn't know any better. Thanks guys.
-Scott- |
Firefighter
Re: blower switch
Re: blower switch
I don't know why, but i keep running across this.
my truck for example, had a 3 position switch mounted in place of the cigarette lighter, with a custom bracket and large knob to hide the fact it was wrong. The PO went through all the trouble of fabbing this up, rather than just replacing the $7 switch. I don't get it ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Re: blower switch
At least the PO of my truck used the correct switch. I guess he didn't put it back in the right spot becasue all the levers were broke. Oh well, just one more thing to correct.
-Scott- |
Re: blower switch
So then what is the cable hooked to that moves with the blower switch?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
its all about the +6 inches
Re: blower switch
that opens up the vent
Lever all the way to the left, closed vent, blower off Lever 1/2 way, vent open, blower off After that, sliding to the right, you have low, med, and hi. |
Re: blower switch
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#12 | |
Re: blower switch
Now if I can just get power to the blower switch!
#13 |
GM Gypsy
Re: blower switch
1972 Custom 10 Deluxe LWB 4x4 2003 Power Wheels Barbie Jeep (2 daughters ya know) ![]() 2004 Silverado Crew Cab Z71- Sold ![]() Here's to your coffin... May it be built of 100 year old oaks which I will plant tomorrow... |
#14 |
Re: blower switch
Biff, that's exactly where mine was located. I guess the PO didn't mount it there cause he told me that was the stock GM mounting location.
-Scott- |
