airbar for 73-87 is ready!
No I do not work for ridetech, saw this on their forums tonight.
Been following the posts since they started working on this awhile back. http://www.ridetech.com/forum/tm.asp...ode=1&s=#12033
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
Re: airbar for 73-87 is ready!
What are the advantages of this over a conventional 4 link?
Shane, I can't answer that directly, maybe the ridetech guys can.
Been following the build, was interested in it because it's a complete bolt on kit, my "fab" sk1llz are sucky, so I thought it would be a good kit for someone without a lot of custom work.
Happy to be here
![]() Join Date: Mar 2000
Essentially it is a conventional 4 link. The advantage is it's a bolt in kit that engineered for a specific application.
It's not for the guys that want to lay frame, but it is a pretty nice set up if you don't want to cut your bed out. ![]()
#5 | |
the # 1 answer . . ....
That does make a lot of sense .... one of my "DUH" moments. I didn't think of it that way and forgot that these models came with leaf springs.
Thanks guys. |
it won't lay frame.so,how low can you go? till the tire's hit?
" Never look up a dead dogs butt." ![]() |
#9 | |
Prob equal to a 5/7 drop but ride better & be adjustable JIC you want to throw stuff in the bed.
Happy to be here
It will go this low...
looks good......is it a member's? i would like to see more.
#13 |
nice setup but ide rather lay frame. or build it myself
#14 |
it is air rides truck... i can get more pics if you want. It will go a couple inches lower if you trim into your bed.
#15 |
Besides the c-notch, is everything else use existing holes in the frame, or do you have to modify?
