02-23-2007, 11:54 PM | #1 |
Turbo 400 to Transfer Case
I am looking at a '82 Jimmy originally a diesel but converted to Chevy 350. The owner stated the 400 trans is bad, but has another 400 but its a 32 spline output shaft instead of the 28 spline that matches the transfer case. Any suggestions on how to match these up or should I just get the 28 spline rebuilt? I was unaware there were two different types. All input welcome.
Thanks Don
Thanks Don '57 Chevy Nomad '70 Buick GSX '72 Cheyene (Boys' truck) |
02-24-2007, 01:44 AM | #2 |
Re: Turbo 400 to Transfer Case
If you feel up to it, you can swap out the input gear to match what you already have. Are you replacing the x-fer case too? If it was already attached to a TH-400, it should have the correct input gear. As far as I know, the 700R4's and TH-350 had 27 spline output and the TH-400's and SM-465 had 32 spline output.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
02-24-2007, 02:06 AM | #3 |
Location: vacaville ca, because it as far from indy as i can be
if it originaly had a th400 it will match the tcase !!!unless!!! he is retarded and is giving you a 2wd tranny with the wrong out put length.
or he doesnt know that he had a 350/700r4 [like said before] |
02-24-2007, 08:40 AM | #4 |
Thanks guys, you answered what I thought. I am familiar with two wheel drive trans, but not four wheel. I will find out what he has today.
04-07-2007, 04:40 PM | #5 |
What is wrong with the Transmission?
The diesel torque converter is all wrong for a gas engine. This is just something to check out before spending too much.
Jamie Blazer86 VE3RSJ |
