Old 02-24-2007, 06:30 AM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Fuel cell behind seat
I am thinking about putting a RCI Aluminum fuel cell behind the seat of my 71' stepside. I has a built in sender and with some minor pipe bending I can use the stock fuel neck. Anyone ever consider this?? It measues 30" LONG X 7" WIDE X 17" HIGH. I measured and I think it will fit. Any ideas?? I was told with a fuel cell you wont get the fumes like the stock tank.
1971ChevyTruck is offline   Reply With Quote
Old 02-24-2007, 06:37 AM   #2
1971ChevyTruck
Re: Fuel cell behind seat
Here is a pic............
Old 02-24-2007, 08:56 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
the only draw back i can think of is either youll have to have the seat back straight up and down or scoot the bottom forward and lose leg room, but i do love the idea of it and hope it works for you, and i dont see why it wouldnt fit, but then i dont know the measurements of the stock tank, but good luck with it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-24-2007, 10:08 AM   #4
Joe67
67 is sold
I agree with the space issue, depending on the configuration, your seat may be at 90 degrees - not too comfortable.
Anyone with a stock tank that smells fumes has something to fix. A properly working OEM setup should have NO fumes inside the cab.
I don't see much to gain by going with a fuel cell inside the cab, unless the cell weighs less than the stock unit and you are looking to shave some weight
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-24-2007, 11:00 AM   #5
1971ChevyTruck
I think there is some misunderstanding...a stock tank Measures 59 3/8 inches x 7 1/4 inches x 16 3/4 inches....so this is the same size....I made a mock tank up and I can have the stock bench seat back....I'll send picks when I'm done.....As for stock tanks not giving off fumes I have been in several trucks and in the summerime most give off some fumes---thats why people are taking the tanks out from behind the seats and putting them in the frame.
Old 02-24-2007, 11:30 AM   #6
Joe67
67 is sold
I see, so the space won't be an issue
I never had fumes in my '67 before I tore it down. A properly functioning OEM setup should have no fumes inside the cab.
Personally, I moved my tank to gain a little legroom and to remove the big old fill tube from the side of the cab.
Old 02-24-2007, 01:05 PM   #7
1971ChevyTruck
I understand that...I wish when I had the truck painted I would have done my homework and moved the tank...but now I am hoping this will work out...I wanted it out from behind the seat so I could mount some subs...but oh well....thanks for the comments
Old 02-24-2007, 01:42 PM   #8
Joe67
67 is sold
No sweat - let us know more about the fuel cell
Old 02-24-2007, 02:45 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
But on a stock 71-72 with the EEC tank it actually has a vent on the passenger side that runs up into the back of the cab, so how could you NOT smell the fumes???
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
