tranny shifting Q
this is refering to automatics ofcourse, but does it hurt or is it bad for the tranny if you shift it manualy???
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Sierra Grande Club
Re: tranny shifting Q
I dont think so.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
upshifting manually is ok but down shifting is hard on the band on t350s, and really hard on the overrun clutches on 700s. Just watch how much braking the tranny does when downshifting.
its all about the +6 inches
while it doesn't directly damage anything... it'sll wear it out sooner if you drive it like a stick all the time.
Do the heel toe thing when ever you down shift it.... kinda blip the throttle a split second before it goes into the lower gear. |
ok thanks guys, i never really downshift it, but once in a while ill upshift it
