Side molding
I removed the side molding from "Fudge" and it has the sticky double back tape from 1977. Ya'll know of something that might help in the removal of this tape without totally mucking up the paint?
I'm trying to go with a cleaner look and am not ready to sand off the tape residue. The rest of the truck's paint is too nice to totally repaint. I've tried some stuff but so far, this tape is hard core. Thoughts?
JP 1977 GMC Sierra Grande (350) 2004 Jeep Wrangler (4.0)
dang its hot
Re: Side molding
3 M makes an adhesive remover that works well, also try a heat gun and a plastic scraper
Re: Side molding
How nice was your trim ? Was it long or short bed ? Would you sell the trim ?
I think there is a tool that the body shops use called a crud thug or something that is basically an eraser on a high speed drill that removes it without harming paint . You might just ask what they would charge . Frank
Born and proudly residing in a Red State ! |
Re: Side molding
Trim was good -- not certain if I'm keeping it off or not just yet. It's a short bed. Might consider selling it or trading for something....
Happy to be here
![]() Join Date: Mar 2000
Re: Side molding
Try WD-40 to start with. If the paint is original you can use thiiner or reducer. If it's been repainted I would go easy on the hotter chemicals. Test a hidden spot first.
Beyond that, Frank has the answer. Use an eraser wheel.
Re: Side molding
Thought about WD-40 but it's been so freakin cold the past few days, I don't want to venture out to the garage. If the 40 doesn't work, I guess I'll have to buy a heat gun.
Thanks for the advise.
The Crazy Machanic
Re: Side molding
blow dryer and wd40 with plastic spatchula. just a thought
Re: Side molding
WD40 and spatchula did it. Didn't need the heat. Have a bit more rubbing but the vast majority is already gone. Thanks everyone for the info.
| Bookmarks |
