Old 02-24-2007, 10:09 AM   #1
meaniam
best way to remove dual knob radio
it appears that the dual knob radio for replacement needs to have the glove box removed. is that correct. anyone know what tools other then a phillips ill need? anything to watch for?
meaniam is offline   Reply With Quote
Old 02-24-2007, 10:13 AM   #2
brak
brak's Avatar
Re: best way to remove dual knob radio
Removing the glove box liner, would definatley give you easier access to the back of the radio, but i don't think it is absolutely necessary.
all you should need is:
Deep socket (preferred) or pliars (little more aggrivating but effective), to remove the nuts around the front shafts that hold the radio tight against the dash.
socket or pliars to remove the support on the back of the radio.
Drop the unit, unplug the wires and done.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-24-2007, 10:26 AM   #3
cdowns
cdowns's Avatar
dropping the heater control unit will give more than enough room to get the radio out
Old 02-24-2007, 10:33 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would recomend removing the inst panel before the glove box liner.
Old 02-24-2007, 10:52 AM   #5
meaniam
thanks for all the advice. it looked a little tight to pulll str8 down. ill need to go back and look at it. as it sounds like the way to go. forums rock. the people one this on rule
