02-24-2007, 10:13 AM | #1 |
4x4 vin #
I have come across some 4x4's with a vin# starting with cc instead of ck. How is this possible and will it be a problem titling the truck in any states
02-24-2007, 11:00 AM | #2 |
its all about the +6 inches
Re: 4x4 vin #
either a bogus VIN plate... or, the truck used to be a 2 wheel drive truck and has been modified, or, the cab was replaced, and the guy doing the work opted to keep the VIN on the cab.
Technicly, the frame and cab VINs are supposed to match. However, many states don't care, and say either one or the other. I would call the DMV with that question after verifying the frame VIN in fact does not match. (It could be the right VIN for the cab and a modified frame instead of swapped frame) Tell them everything about it being totally honest, and if they tell you to go for it, get there complete name and what branch that person works at, and go on with the transaction. |
02-24-2007, 11:03 AM | #3 |
Re: 4x4 vin #
Neither of mine have CK.My 2 both just start with K...... As I decoded them they are 4x4s as "K" means 4wd series.Was there different VINs?
Start of VIN on 69:KE149J Start of VIN on 71 :KS107.... No "C" anywhere,meaning mine are matchhing 4x4 VIN #."C" indicates a 2wd so Longhorn Man is likely correct on a cab swap Last edited by 1969k10stepside; 02-24-2007 at 11:07 AM. |
02-24-2007, 12:19 PM | #4 |
Re: 4x4 vin #
Dustin,neither of your are`72s.GM added the pre-fix in`72.
Chevy:CC=2wd CK=4wd GMC:TC=2wd TK=4wd
02-24-2007, 01:15 PM | #5 |
Re: 4x4 vin #
OK,I see.Thanks Tim
02-24-2007, 01:20 PM | #6 |
Re: 4x4 vin #
i actually ment to say something about that.
02-24-2007, 02:09 PM | #7 |
Re: 4x4 vin #
You covered it good.I had to double check if you mentioned it.I thought I`d elaborate(you know I know you know).
02-27-2007, 11:46 PM | #8 |
Re: 4x4 vin #
Confusing crap a little more, the VIN on my '69 starts BKE...
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
02-27-2007, 11:56 PM | #9 |
Re: 4x4 vin #
can you post a photo of your VIN plate?
02-28-2007, 07:30 AM | #10 |
Re: 4x4 vin #
That was a promotiomal model ordered by Burger King.Believe me,I know these things.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-28-2007 at 07:30 AM. |
02-28-2007, 07:56 AM | #11 |
Re: 4x4 vin #
when i converted my 70 from2 to 4 wd i left the 2 wd vin on it. it was cheaper for me to register it that way.never plan to sell it so it should nt be an issue.
03-03-2007, 10:59 AM | #12 |
Re: 4x4 vin #
I might see the old girl today and if I do I will get pictures. Pretty sure the vin is written in black grease pencil on the firewall as well.
03-19-2007, 09:58 PM | #13 |
Re: 4x4 vin #
Finally got to visit with my Blazer yesterday:
Burger King? Not so sure on that one
03-19-2007, 10:03 PM | #14 |
Re: 4x4 vin #
Thats "B"izzare. first I've seen.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
03-19-2007, 10:07 PM | #15 |
Re: 4x4 vin #
Me too,kind of looks like a "D" instead,but still never seen anything like it
03-19-2007, 10:35 PM | #16 |
Re: 4x4 vin #
Yeah, some PO repainted over everything on the truck, and the lighting in the picture sucks making it worse. It is really a "B".
03-19-2007, 11:04 PM | #17 |
Re: 4x4 vin #
wow
