Old 02-24-2007, 10:21 AM   #1
manimal
manimal's Avatar
power steering question
I am putting the power steerin gear box from my '84 'burby onto my 69 C10. will the '84 pitman arm work on the '69 drag link? Or do I have to use the entire steering linkage from the '84? will the idler arm work the same?Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-24-2007, 02:00 PM   #2
manimal
manimal's Avatar
Re: power steering question
ttt
-Lance
Old 02-24-2007, 03:52 PM   #3
68speedalert
Semi-Senior Member
68speedalert's Avatar
Does your 69 have power steering? If so, use the pitman from it.
If you now have manual, I think you need find a pitman for a 69 w/ps.
I can't say for sure, but I believe the stud from the pitman to the centerlink is larger on the 84.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 02-24-2007, 11:07 PM   #4
manimal
manimal's Avatar
So a pitman arm from a 69 w/power steer will work on the '84 box?Thanks
-Lance
-Lance
Old 02-24-2007, 11:21 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Exclamation Re: power steering Box Question
I got a good question i'm having a problem with the steering box i have the problem i'm having is when i make a right hand turn i seem to not have a tight turn but on the left hand side it gose a little further i thing i have 2 3/4 turn on the right and 3 turn to 3 1/4 and i like it to have 3 1/2 on both sides of my 1965 3/4 ton truck put it out of a 1977 3/4 ton suburban some have told me to get the corvett steering box
stsalvage is offline   Reply With Quote
Old 02-25-2007, 12:21 AM   #6
68speedalert
Semi-Senior Member
-Lance
I'm gonna say yes. They use the same box, except the 84 may have metric line threads.
