Old 02-24-2007, 11:24 PM   #1
stsalvage
Scrapper 1
stsalvage's Avatar
Exclamation steering box question
I got a good question i'm having a problem with the steering box i have the problem i'm having is when i make a right hand turn i seem to not have a tight turn but on the left hand side it gose a little further i think i have 2 3/4 turn on the right and 3 turn to 3 1/4 and i like it to have 3 1/2 on both sides of my 1965 3/4 ton truck put it out of a 1977 3/4 ton suburban some have told me to get the corvett steering box
stsalvage is offline   Reply With Quote
Old 02-24-2007, 11:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: sterring box question
it was never centered when it was installed.
A vette box wouldn't even work on a truck.
Old 02-25-2007, 12:57 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
Re: steering box question
I know they make a box out there that has 3 1/2 turns lock to lock cus i hual a trailer don't car if i rub a little just need a little more turing radiess
Old 02-25-2007, 01:22 AM   #4
Shadetreemechanic
Shadetreemechanic's Avatar
If it is anything like mine I would jack the front end up. Center the tires disconnect the steering box from from tie rod and turn the steering box 1/2 turn to the right.
Shadetreemechanic is offline   Reply With Quote
Old 02-27-2007, 11:42 PM   #5
69TowRig
I found that my 4x4 had this problem also, but didn't realize it until I swapped my manual box for a PS box. The drag-link was too long, causing the box to be off-center when the tires were straight ahead. I don't know the steering setup on the 2wds but I suspect that you will have to adjust the tie rods on both sides to get the box back to center when the tires are straight ahead. Sounds like whoever has been doing alignments on the truck hasn't been doing the whole job.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 02-28-2007, 12:03 AM   #6
Big Ants71
Big Ants71's Avatar
I think your pitman arm is off a tooth or two,the best way to center it is,turn your steering wheel lock to lock (all the way left then right)count your total turns and devide them in half,that would center you gear box.now remove your pitman arm from the gear box and point it straight now rebolt your pitman arm and drive it to get an alignment.
BIG ANTS 71
Big Ants71 is offline   Reply With Quote
Old 02-28-2007, 12:07 AM   #7
kwmech
Cannot be done---there is a 4 slot master spline
