Old 02-25-2007, 12:29 PM   #1
meathead95
computer illiterate
meathead95's Avatar
engine guru's
i think the engine in my k20 is junk when i got it it ran rough. so i replaced the quadrajet and points with a new hei and edelbrock 600cfm carb and it ran a little better but i still had never taken it on its maiden voyage as i was waiting on brake parts and now it will not start at all and i still have spark and fuel so i ran a compression check on the cylinders and this is what i got
1-70 2-90
3-80 4-110
5-70 6-60
7-95 8-75
i would say it needs a rebuild but do you think these low compression numbers is why it will not run?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-25-2007, 12:52 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: engine guru's
Generally, any compression pressure under 100 will be a dead cylinder- and you have plenty of them. Most likely tapered cylinders & worn rings. Squirt 3-4 shots of oil from an oil can in each spark plug hole & retest compression. Any cylinders that come up considerably are ring/ cylinder wear. Any that don't are worn valves/ seats or a blown head gasket.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 02-25-2007, 01:25 PM   #3
meathead95
computer illiterate
meathead95's Avatar
Re: engine guru's
5, 6, 7, and 8 already had oil in them lol.........
72 2wd blazer
72 swb 4x4
Old 02-25-2007, 01:37 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: engine guru's
INO, you cant rely on those numbers as the car was cold. Get it to fire up and once warm recheck. Then you have solid numbers to work with.
Did it work after the HEI install?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-25-2007, 01:56 PM   #5
meathead95
computer illiterate
meathead95's Avatar
Re: engine guru's
yes i installed the hei and carb and it ran great in the garage for a few weeks and it got really hard to start and then it wouldnt start and i noticed the rh intake gasket was leaking a little so i took it apart again and replaced the gasket and now it wont run at all.
72 2wd blazer
72 swb 4x4
Old 02-25-2007, 04:37 PM   #6
Ron 586
RIP Mr Ron
Ron 586's Avatar
Re: engine guru's
Keith, check and make sure that the distributor didn't get installed wrong. Yes it has low compression but if it ran before you pulled the intake it should still run. Just double check everything and make sure you didn't let it slip a tooth or two.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 02-25-2007, 05:01 PM   #7
cableguy0
Re: engine guru's
sounds like you got a big combination of stuff fighting against you. if the plugs are oil soaked they are fouled and need replaced.it sounds like its very worn engine but it should still start up. after you get some decent plugs in there make sure you have the distributor in the right place and the correct timing.also you could have a massive vaccum leak if the intake gasket isnt properly seated which will also cause it to not start. recheck everything and make sure the bolts are tights on the intake as well as the carb
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-25-2007, 05:39 PM   #8
nvrforgotten52
nvrforgotten52's Avatar
Re: engine guru's
definitely check the valve seats on the heads when you rebuild it. they are probably non hardened seats made for back in the day when people ran leaded gasoline... they will sink into the head and you wont get a tight seal from the valves. but it sounds like you have piston ring problems to begin with anyways
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 02-25-2007, 09:24 PM   #9
NPilot1975
NPilot1975's Avatar
Re: engine guru's
Double check that you didn't get the distributor 180 out. Engine will crank but definitely not sound right. You can also rule out a fuel problem with a little starting fluid, if it will fire on it then it is fuel.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 02-25-2007, 10:09 PM   #10
meathead95
computer illiterate
meathead95's Avatar
Re: engine guru's
i put new plugs in it and i took the dizzy out and redid it 3 times and still cannot get it to start im gonna go get the module in the dizzy tested tomorrow it is a brand new summit hei but i guess that doesnt mean anything
72 2wd blazer
72 swb 4x4
Old 02-25-2007, 10:21 PM   #11
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Re: engine guru's
My .02 - look at the compression. Tapered holes is what I'm throwing at it here. Hard starting because it takes a bunch of moving air to create useable compression, the only way to off-set that is to pump like hell on the throttle while cranking, to make good on the fuel ratio.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 02-25-2007, 10:24 PM   #12
meathead95
computer illiterate
meathead95's Avatar
Re: engine guru's
when it did run before i had to pump it like hell to get it started. and now nothing
72 2wd blazer
72 swb 4x4
Old 02-25-2007, 10:36 PM   #13
lngbed71
lngbed71's Avatar
Re: engine guru's
I don't think it is ignition related here, especially a new dizzy module, you don't have enough heat in it to make a new one go bad. If you have set the dizzy right as much as 3 times, don't seem right that it would be 180 out. I just think you are out of compression. You may want to try advancing the timing a bunch. If it gets running agin, drop some Rislone or an additive in her to help short term with combustion ratios. Bad compression sucks.
Land of the free
Old 02-26-2007, 02:32 AM   #14
stsalvage
Scrapper 1
stsalvage's Avatar
Re: engine guru's
well all i can say to rebuilding your engine to buying a new one at the GM dealer might be worth checking into here in calif to have a eng rebuilt will cost you 1300.00 1100.00 if you do some short cuts Now GM goodwrench has a deal out for a std bore 350 4 bolt main 240 hp 300 pounds of torq or is it 350 pounds of torq for 1400.00 out the door
this is not a rebuilt or recondtion engine its Brand new nothing inside this eng is used so you get a 350 std bore with valve covers and a oil pan and timeing cover olready installed
all you have to do is put intake water pump and HEI in and bam your ready i've done 1 so far no problems and they give a 1 year 12k warrinty with it and if you put it in and you have a problem with it youcan got back to the dealer ship where you bought it from and most of the times they will take your old one out and drop the new one in as long as you did not modifye it in any way like adding a cam or putting roller lifters in they will replace it
and plus there is NO CORE your buying a brand new engine GM dose not want a Core
stsalvage is offline   Reply With Quote
Old 02-26-2007, 07:56 AM   #15
meathead95
computer illiterate
meathead95's Avatar
Re: engine guru's
i also forgot to mention the strangest thing ive ever seen was after carnking it to try and get it to start plugs 2,3, and4 where gas soaked 5,6,7, and 8 where gas and oil soaked but #1 was completely dry?
72 2wd blazer
72 swb 4x4
