02-25-2007, 03:54 PM | #1 |
Removing the 350
Ok I have the rented cherry picker here and I am ready to start to pull a motor. I have everything unhooked except the carb,tranny,heater hoses and I need to move the electrical. Also when do I unscrew the bolt from the tower to the mount? When I get int engine on the chain and pulled up some?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-25-2007, 04:18 PM | #2 |
Re: Removing the 350
Anytime that is handy. It will go nowhere until you lift it up. It also will make it easier to remove if you remove the starter (wiil not have lift it as high to bring it forward.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-25-2007, 04:23 PM | #3 |
wnc tvman
i just pulled my small block, i removed the trans 1st, unhooked everything and lifted the engine out in 5 minutes.
Oz WNC 67 Short Fleet 350 4speed 70 Short Fleet 327 4speed |
02-25-2007, 04:28 PM | #4 |
Tranny will be staying in. Just the engine is coming out.
02-25-2007, 05:34 PM | #5 |
if your leaving the trans in should be a piece of cake. id undo the mounts b4 you put tension on it...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
02-25-2007, 05:43 PM | #6 |
Just for giggles, verify that the trans mount bolts are actully there. (don't ask me how I know that this is important)
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
02-25-2007, 06:12 PM | #7 |
its all about the +6 inches
yes...very important to make sure the tranny is mounted in place.
Something to keep in mind, (for next time) most rental places will offer a 2 hr or 4 hr rental at a reduced rate. So if you woulda had everything ready, you coulda rented the hoist, pulled it out, returned the hoist, and saved some bucks. |
02-25-2007, 06:16 PM | #8 |
put a jackstand under the front of the tranny dont let it hang off of the mount of it will probably rip the mount in half and end up laying on the floor
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-25-2007, 06:55 PM | #9 |
^My thoughts exactly. Also take a piece of baling wire and put it through the two holes in the front of the tranny to keep the torque converter in place.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-26-2007, 03:10 AM | #10 |
Scrapper 1
man i'm in the junk bussiness and i pull engs all the time and trust me bring the trans with it trust me its a ***** to aline all the bolts and to get the shaft into place and plus when its time to put the eng and trand back in is goise in all in one time remmber to drain all the oil befor you take eng and trans out cus it tends to make a mess
02-26-2007, 03:37 AM | #11 |
Designated A-hole!
I agree with most of what stsalvage says, but to line the engine and tranny back up all you need is a couple of long 3/8's bolts (I used starter bolts cuz I had them, but they're not cheap). Cut the heads off of the bolts and use a grinder to square the ends some (just enough to be able to turn with a pair of pliers). Put them in the bottom bellhousing bolt holes and use them to line the tranny and engine up. Then you can start the bolts in the next hole up. Granted I've never done this putting the engine in with the tranny in place, but I've used it several times to stab the tranny with the engine in place.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-26-2007, 03:33 PM | #12 |
I've always pulled them one at a time personally. Stabbing the engine with long bolts with the head cut off is just as easy as doing the tranny to the engine.
just becouse of the fact that you'll never get all the tranny oil out is reason enough for me to drop the tranny on it's own. |
