02-25-2007, 06:06 PM | #1 |
Long Fleet Club
Where the 700r4 and the e-brake dont get along.
I have the 700 in and the crossmember moved. Now I need some ideas because if I put the crossover cable for the e-brake in front of or behind the trans mount it still pushes on the cable. I'll get some pics of it soon.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
02-26-2007, 12:25 AM | #2 |
Long Fleet Club
Re: Where the 700r4 and the e-brake dont get along.
Anyone with a 700r4 got any ideas or have solved this already? If so I would like to see it.
02-26-2007, 12:33 AM | #3 |
Let me know what you did to get your 700 in I would like to come over and look at it. I live in Deer Park too.
02-27-2007, 06:42 PM | #4 |
Long Fleet Club
ttt
02-27-2007, 07:11 PM | #5 |
Cereal Killer
redo the trany crossmember?
If I dont do it....somebody else will. |
02-27-2007, 07:12 PM | #6 |
If you find the correct way to solve this problem please hit me back and let me know i am facing the same problem
02-27-2007, 08:10 PM | #7 |
I survived Dead Man's Curve.
You may have to use an aftermarket crossmember. We used one, which is a lot smaller, consisting of a single tube with a mounting platform in the center, and two, vertical mounting plates on the sides. Doesn't touch the E-brake setup at all.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. |
02-27-2007, 08:27 PM | #8 | |
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
02-27-2007, 08:27 PM | #9 |
just fabricate up some stand offs for the brake cable to go thru for proper clearance and mount on frame or crossmember as needed
02-27-2007, 08:40 PM | #10 |
Cdowns: thats what i did when i installed my 700.. they work fine i just welded a couple little brackets with holes with a plastic bushing inside, its worked fine ever since. i had it rubbing for a while before i did that and it didnt seem to hurt anything anyhow.
02-27-2007, 11:23 PM | #11 |
Long Fleet Club
the crossmember isnt in the way. I had a powerglide trans in there and the crossover to the passenger side was under the drive shaft. Now with the 700r4 it is basicly in the middle of the trans mount but I have it pulled back. the holders in the frame i'm thinking about shortening them and hopfully it would pull it far enough back. It has been to dark to get a pic of what I have now but I'll get one befor I try it.
