Old 02-25-2007, 06:14 PM   #1
Nachos82
67 LWB with surface rust all over
Hi all, found a 67 LWB local that I am looking at. Problem is that it is covered with lots of surface rust. My question is how hard is it to work with a truck that is so covered with rust. I never really messed with anything like this before. What are your opinions. Truck is on its 2nd owner and the current one bought it like it is with the 327 and 4-speed on the floor. Has a posi rear that is also listed on options sheet. Seems to be all original.
Nachos82 is offline   Reply With Quote
Old 02-25-2007, 06:22 PM   #2
Ram-Man
Ram-Man's Avatar
Re: 67 LWB with surface rust all over
From my experience that surface rust comes off pretty easy. The metal on these is alot thicker than the vehicles today. I have seen alot of them like that one.
Ram-Man is offline   Reply With Quote
Old 02-25-2007, 06:36 PM   #3
rage'nrat638
rage'nrat638's Avatar
looks like a sweet old truck
that will buff right out
nothing a little work won't cure
rage'nrat638 is offline   Reply With Quote
Old 02-25-2007, 07:20 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some of it may be problematic, the lower door there looks pretty thick.
Old 02-25-2007, 07:32 PM   #5
Shane
Shane's Avatar
Scotch brite pad and some elbow grease and you got yourself a rat/beater/driver.
Shane is offline   Reply With Quote
Old 02-25-2007, 08:19 PM   #6
cableguy0
some time and elbow grease will take care of that. compared to around here that truck isnt even rusty
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-25-2007, 09:41 PM   #7
Bob B.
Surface rust is not a problem as long as the metal isn't pitted real bad. Be sure to use a metal prep. (follow the instructions!) before you prime it. And, paint it soon after it is primed, or that rust will come right back.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 02-25-2007, 09:51 PM   #8
RedZ71
Junior Member
RedZ71's Avatar
that one actually looks pretty good in all the typical "bad" spots.
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 02-25-2007, 09:55 PM   #9
underdog8704
NCStroker
underdog8704's Avatar
could be a really cool looking 'shop truck' in my opinion.
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 02-25-2007, 09:56 PM   #10
Nachos82
Thanks for all the info guys. You say scotchbrite pads, can you also use just rough grit sandpaper? How about wirewheels? I know sandblasting will most likely warp panels, but other then the things I mentioned is there any real issue with it when it comes time to paint? The price is not bad and from what I saw all the options list info in the glovebox is still on the truck as it was from factory. For rust preps, are you talking about the chemical stuff you apply and it stops coats the rust? How easy it that stuff to paint over? I just dont want to spend time working on it and painting, then the rust all comes back through.
Old 02-25-2007, 10:03 PM   #11
Zoomad75
K5Camper
Zoomad75's Avatar
Thats not rust thats "patina"! Rat Rodders would kill for that.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-25-2007, 10:10 PM   #12
rage'nrat638
nope D.A. complete truck down prime with self etching sealer primer and paint as you would any thing else. thats how most the model t's and pre 50's cars and trucks look before redone. they sit out in fields for years. it's the hot sun that burns the paint off there in texas.
thats a very nice truck for sure.
Old 02-26-2007, 10:31 AM   #13
Nachos82
Thanks again guys. I will let you all know how things go with this one.
Old 02-26-2007, 10:47 AM   #14
Chevy_Man
Tightwad
Chevy_Man's Avatar
I would buy that truck in a heart beat surface rust is easy to deal with as long as its not all pitted up real bad. But as far as i can tell its not from the pics..BUy BUY BUY BUY!!!!!
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 02-26-2007, 11:36 AM   #15
Don`t use a heavy grit.You`ll make work with swirls and gouges.Be patient and have lots of elbow grease on hand.Definately treat with a rust inhibitor.I prefer the Permatex spray on.Some leave a white crusty layer that needs sanded.Kinda self-defeating.If you spray the Permatex like you`re painting,let it dry,you can prime straight over it.
Old 02-26-2007, 12:23 PM   #16
72CSTC5
72CSTC5's Avatar
Sand the truck to bare metal, use a "black" roloc strip disc to get in to any deep pits, spray some ospho on the metal, watch it turn black and then start from there with primer to the top. Very easy fix.
72CSTC5 is offline   Reply With Quote
Old 02-26-2007, 12:49 PM   #17
cdowns
cdowns's Avatar
the one area on the truck i'd really check would be the rust by the drip rail and around the windshield area
Old 02-26-2007, 01:45 PM   #18
mrein3
mrein3's Avatar
I had a similar situation. See pictures below.
What I did is:
1. "Sandblaster" disk in my grinder. 3M makes it. It is purple and takes paint, bondo, rust, everything off. Don't be stupid. Use a decent respirator with this item. Who knows what is in that dust.
2. DuPont "Kwik Prep". Only in the attached pictures I used the similar PPG product. It is an acid that etches the metal. This is to get to the rust in the pits that the 3M disk didn't remove. Follow the directions on the package.
3. Epoxy primer.
4. Color.
I used the acid etch stuff under many projects and have yet to have any rust come back through. I can never remember the name of the PPG product but if you search on the Google for DuPont Kwik Prep you'll find what I'm talking about.
I'm sure the products others listed here work but I KNOW the PPG and DuPont products are made to go under their refinishing products.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-26-2007, 03:38 PM   #19
gouldie
nice looking truck, i have a white 67 covered in surface rust as well. i dont have a whole lot of time or money to work on it so i just took care of the bad spots and am letting the surface rust stay, because it does look cool, until i get some extra time to worry about how it looks
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
