02-25-2007, 11:45 PM | #1 |
Corporate 10 bolt vs. Dana 44
Been trying to find a Dana 44 8 lug front axle for my 3/4 ton conversion on my 1/2 ton, but they're hard to find and the ones that are available are about the same price as 60s. I have located a 8 lug Corporate 10 bolt front out of a mid-80s Burb. I've never been a fan of these axles, but that was always in the rear. I don't need 60 strength as I don't do anything really hard or abusive. Are these front axles good or junk?
02-26-2007, 01:44 AM | #2 |
Re: Corporate 10 bolt vs. Dana 44
D44 and 10 bolt are identical in strength.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-26-2007, 04:37 PM | #3 |
That or you can convert your 6 lug dana 44 to an 8 lug....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-26-2007, 06:34 PM | #4 |
They have 8 lug 10 bolts to...
02-26-2007, 08:33 PM | #5 |
The later 10 bolts are a tad stronger, only because they have 30 spline inners. Other than that, the are about the same strength.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-27-2007, 12:04 AM | #6 |
if you already have a d44 6lug just get the hubs and backing plates from the 10 and put them on your 44.
Earl 68 2500 4x4 GMC Burb |
02-27-2007, 12:39 AM | #7 |
Location: vacaville ca, because it as far from indy as i can be
02-27-2007, 03:36 PM | #8 |
Suburbans RULE!
Dana 44's have 30 spline inners too.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
04-28-2007, 05:30 PM | #9 |
I just noticed that my Corporate 10 bolt has the pinion 1 inch inboard from my dana 44, thus the axles are 1" shorter on the DS and 1" longer on the PS... I guess 1" won't hurt the front driveshaft...
04-30-2007, 09:12 AM | #10 |
The banjo fitting on the calipers is different on d44 and 10bolts. You'll either need to replace the brake line or keep your original callipers. Not a major problem but its the small things that you dont think of that slow you down.
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
04-30-2007, 10:46 AM | #11 |
yep, corp 10 is a metric banjo bolt
