Shifter Removal
What is the best way to remove the shifter from my 72 chevy 4speed. I know it lookes like there are 2 role pins on the sides. DO these have to be removed? I also noticed that it lookes like there is a cap holding the shifter in. Is there anything that O can do with this? Please help, I am going to be putting my Carpet in the weekend and it would help not to have this in the way.
Thanks Travis.
1972 Custom/10 Longbed In the works |
All you need to do is push down on the cap and turn about a 1/4 turn and the shifter will pull out. I can't remember if you have to turn it clockwise or counter-clockwise. I seem to think it is counter-clockwise but it has been a while since I have removed one. Hope this helps.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
Push down on the ring/cap at the bottom of your shifter and turn it 1/4 to 1/2 turn anti-clockwise and the shifter will pull out.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
It will not push down or turn. Is there any other way??
#5 | |
Bloo
thats th eonly way i know, just keep pushing, put all of your weight on it, there harder then heck to get to go down.. (the last time i tried i weighed 155, and liked to never got it down)
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Location: Help! I'm in an office park with its own network of freeways!
A bit of WD40 helps too. Just be careful not to use too much & not be able to get a grip on it. Gashed my hand pretty good on the heater box with that stunt.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
